Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 20-01-2012, 15:30
David Kaplan David Kaplan is offline
FRC #3464 (Sim-City)
David Kaplan is an unknown quantity at this point
How to power the Kinect on the robot.
I've been going through all the forums trying to figure out how to power the Kinect on the robot. (I'm leaving the programming question to others...)
I can disconnect the Wall-wart transformer/rectifier and have a cable that gets fed 12VDC. However, how do I connect it to the PDB? The dedicated 12V connector goes to the Wi-Fi. The main outputs have 30A breakers or something ridiculously high for the 1+ amps the Wall-Wart puts out.
Can I get several amp breakers for the PDB? Any other suggestions?
One of our team members thought of using the spike relay as it will take a small fuse, but wouldn't that have to be turned on during initialization... more work for the programmers.
Comments/Suggestions are appreciated.
Unread 20-01-2012, 15:53
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: How to power the Kinect on the robot.
You can get smaller amp rated Snap Action breakers online at:
http://www.snapaction.net/pdf/vb3.pdf
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 20-01-2012, 16:47
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
I try to find at the manual they don’t mention any thing
TEAM 1946-Tamra
Unread 20-01-2012, 16:48
If your programmers are able to successfully use the kinect on the robot, they can turn on a spike in their sleep. On the other hand, if you are worried about turning on a spike, trying to put a kinect on the robot may not be the best idea.
Unread 20-01-2012, 16:56
Oh, programming the Spike isn't a problem... just trying to keep things simple. If I can legally plug a kinect into the PDB with a small Snap-Action breaker, and perhaps plug a panda board into the PDB with a 12V-5V DC-DC converter we're golden... I know these can PHYSICALLY be done, but concerned about legality.
Unread 20-01-2012, 17:03
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Be careful about using different snap action breakers. I think there is a rule that you can only use 20, 30, 40 amp breakers on the robot.
But don't quote me
Unread 20-01-2012, 17:14
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
R43 Blue box
Smaller value Snap Action auto resetting breakers may be used on the PD Board for circuitry not defined above.
In addition to the required branch power circuit breakers, smaller value fuses or breakers may be incorporated into custom circuits for additional protection.
So you may use a 20A breaker, or substitute a smaller one, but it must be the same make, model, etc of the ones included in the kit.
Personally, I would use a 20A that you already have, and put a fuse inline if you are worried about trying to protect your device. In reality I have never seen a fuse protect a device that was miswired, unless that device had a crowbar circuit built in.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 20-01-2012, 17:22
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
One thing to consider is that the PDB doesn't regulate the voltage outputs, so you could potentially end up somewhere in the mid 13V range with a fresh battery or higher.
"Items specifically prohibited from use on the Robot include:
circuit breakers used on the Power Distribution (PD) Board that are different from the Snap Action breakers provided in the KOP,"
So you should be able to go down to 20A breakers, but nothing less than that. I don't see why you couldn't make a little regulator circuit for the Panda Board.
If you guys DO get this working, I will have to come by and see it. With an OMAP I guess you'd be running some flavor of Linux and running the SDK. The fun would be in interfacing to the cRIO. LOTS of code. LOTS of time. Good luck to you!
- Bryce
EDIT: WHOOPS! Yep, smaller Snap Actions are allowed. Thanks Justin.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 20-01-2012, 17:32
I would suspect that the voltage dips may be a larger problem than the 13ish volts of a fully charged battery.
Unread 20-01-2012, 18:00
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
But don't quote me
Yes, watch out. Something like this sounds right. Ask FIRST or read the manual before doing anything.
It kind of sounds like FIRST didn't really plan out how teams might use the Kinect on the robot. They really meant it for the driver station. So now that it is proving to be quite difficult/not easy, it's kind of a loss to us because we've got to get it working in 6 wks. Maybe there wasn't much they could do, but it's kind of a bummer.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 21-01-2012, 21:10
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
That is a REALLY good point. I guess it all depends on whether the Kinect has a regulator build and how low it drops the voltages.
- Bryce
Unread 22-01-2012, 04:04
yara92's Avatar
AKA: Mohamed
Do you mean to use the Kinect on the robot. They really meant it for the driver station. There is no need to contact with the Robot.
I hope I understand right that should connect with classmate. So there is no need to connect with Robot.
TEAM 1946-Tamra
Unread 22-01-2012, 20:12
RoboMaster's Avatar
Correct. FIRST meant it for the driver station and you don't have to put it on your robot.
But FIRST has allowed us to put it on the robot if we want/can. Benefits include being able to sense the environment really well.
Unread 27-01-2012, 23:57
MPlant MPlant is offline
FRC #0008
MPlant is an unknown quantity at this point
Just jumping in as this rather pertains to me -- has anyone been able to power the kinect on the robot yet?
Unread 28-01-2012, 07:12
Our systems team has changed its mind as they weren't happy with the resolution the Kinect provided, but we had been planning to cut the power cord from the output of the wall transformer/rectifier and connect it to the PDB with a smaller SnapAction breaker than provided by FIRST... never did get to try it though...
