Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 01-20-2012, 05:37 PM
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: CANJaguar
Originally Posted by Kodiak View Post
Ha, how can the wire be too long? on such a short distance with data flying at 1mbs and the Jaguars acting as switches. Also I would like your input on this, for Joystick input, would it be best on Periodic or Continuous?
It possibly has to do with loading down the CAN cable driver. I think the total cable length is something like 20' if I remember right. One suggestion was to buy a 20' cable and use it. If you need more, you've used too much.
Read joystick should probably go in Periodic. Continuous will read the joystick as fast as possible. Periodic will read the joystick at precise intervals (200Hz I think). Honestly, in reference to the system response time of "Joystick moved -> Joystick value read -> Joystick value interpreted -> Motor value sent -> Motor starts moving", the moving of the motor is the longest part (by quite a bit).
Running in continuous only makes more requests and sends more control packets (unnecessarily) utilizing more system bandwidth.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
