Go to Post 50 years from now, the FRC will still be waiting and hoping for a water game. That's my prediction. - TheBoulderite [more]
Unread 20-01-2012, 17:26
rp181 rp181 is offline
FRC #0662
rp181 is an unknown quantity at this point
Quadrilateral of Best Fit
Our team is attempting to have functioning vision. At this point, we have an algorithm to detect blobs, compute the convex hull of the blobs, and calculate the area score and AR score.
Assuming I can pick out which polygon represents the square, how do I go about extracting the 4 corners of it? The computed polygon has around 20 vertices every time, and in order to do the necessary calculations, I need the 4 vertices of a quadrilateral that best describes the shape.
How would i go about this?
Unread 20-01-2012, 17:59
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Quadrilateral of Best Fit
Assuming your computed polygon actually is a quadrilateral, and the larger number of vertices is simply due to slight camera error, you could run an algorithm that groups nearby vertices into a single point, creating 4 points that are a rough quadrilateral.
Attending: MN Duluth Regional
Unread 20-01-2012, 18:19
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
I guess you could check the angle between each of the vertices and cherrypick out the vertex with the angle closest to 180 and repeat until there are only 4 vertices left. Just an idea though. I haven't actually tried that.
Unread 20-01-2012, 18:36
I think it will be easier to find a solution if you think in terms of slope and intercept, instead of x and y.
This might help (or terrify): http://www.cse.unr.edu/~bebis/CS791E...esentation.pdf
Unread 20-01-2012, 18:48
One of the things you might attempt is to visit the vertices and connect lines that almost touch and are almost the same slope. This will eliminate collinear line segments.
Years ago I implemented some decimation routines for a pen plotter. The algorithm involved looking at a progression of points and determining if they were within an error cone that extended from the first point. The purpose was to only transmit the points needed to draw the shape and leave out the points that barely wiggled the pen or were just segments of a straight line.
To find a corner, a similar routine could identify points roughly shared between two segments where the angle is between say 60 and 120 degrees.
Finally, while this will help to eliminate collinear points, you will then want to determine if it is a quadrilateral. Sounds like a fun challenge.
Greg McKaskle
Unread 20-01-2012, 19:04
FRC #0662
I think eliminating co-linear segments and certain vertices is the hint I needed. After that, I believe looking at the angles will work.
I tried to simply measure the angle between points and pick the best one, but it was almost good. I believe the jaggedness of the line resulted in a false positive. If two points are very close and differ by a small amount, the angle gets very steep very quickly, with resolution limited by the pixels.
Has anyone else gotten good vision tracking in Java done? Another problem we are finding is an excessive glare, making the target unrecognizable. Hopefully, it will be different with competition lighting (very low ceilings in our build space).
Unread 20-01-2012, 19:23
Can you share the images with the glare? I'd love to give it a shot.
Greg McKaskle
