#16
Re: Motor speed control uning Jaguar
R61 A also would prohibit the PWM connection if you are using canbus since there is no way for you to turnoff the PWM signal. I expect if you tried to do it the Jag would default to one ignoring the other completely. The Jag firmware 101 (another thread) seems to have fixed an issue with the canbus. A trashy signal use to take the Jag offline until a power reset. It now will try to reset itself. |
#17
I have downloaded the specs for the Black Jaguar to research exactly that question. The spec sheet claims 1 million transitions per second. So the 250 counts per revolution is 4 transitions per line, so 1000 transitions per second. That means that it should handle 1,000 revolutions per second, or 60,000 RPM.
My problem is getting a feedback signal to the Jaguar. Currently I have a left over magnetic encoder, but so far the Jaguar has refused to display a speed or position signal from the magnetic encoder output, which means the PID just ramps up until the Jaguar limits out. Mike Quote:
#18
That would explain the problem. The magnetic encoder I am using generates 2 analog signals that are in quadrature. I thought that the Jaguar could handle that from some of the documentation, but perhaps not. I also tried using the digital Index pulse only, but so fat have not gotten that to work.
The 5/16 inch bore digital encoder should arrive today, and I will try again with that. Mike |
#20
Now I wonder if you can run some Jags on CAN and other jags on PWM, on the same robot. The rules appear to not prevent this, so long as one OR the other is used, never both. You definitely can't use both PWM and CAN on a single Jaguar. I'm not sure it would even work. Encoders: This Thread has more info on the same topic. |
#21
The larger shaft size digital encoder arrived finally, and I got it mounted. Using 2 lantern batteries, and they frequently over current/under volt and crash the Jaguar, requiring a full reset and start from scratch (Note to TI developers, please PLEASE add a save current configuration so that we don't have to reenter EVERYTHING after each reset?).
As long as there were no sudden jumps, it works on digital using the 'encoder' input. I did have to swap the motor leads. I am not sure if 'encoder inverted' would work as well. I also found that at low rpm, like below 100, the TI firmware does not handle speed measurements correctly. Each encoder pulse causes a sudden huge jump up in speed, causing the PID to immediately stop or even reverse (and cause weak batteries to under volt and crash the Jaguar), then go back to zero and let the PID integrate back up. An integration term of 0.0002 is too small to affect the output, 0.003 will ramp up a volt or two per second. With a 15Khz PWM rate, the PID equations may be run at the same speed, and long gaps of time steps with no encoder pulses confuse the firmware. Instead of measuring time between pulses to handle slow speeds, I think they are counting pulses per time period and doing some averaging. All this really means is that direct shaft connection to a drive wheel may require a VERY high line per revolution count, but high motor speeds should be ease to work with. I got up to 1700 rpm before the batteries lost it, and logging 20 times a second and it was stable to a few rpm. The next big problem is that the WindRiver user's guide has sections for serial and I2I interface, but they are blank, no text. And looking in the code files, there are blocks for Jaguar (PWM mode only), Victor, PID (software version only), serial interface (raw interface), PWM, but nothing that uses the serial interface to control the internal PID in Jaguar. Does anyone know where there is code interface between the cRIO and the Jaguar in C++? Mike |
