Go to Post I believe that "going home a winner" is more a matter of perception than anything else. - JesseK [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-01-2012, 17:53
Dr Fritz's Avatar
Dr Fritz Dr Fritz is offline
AKA: Fritzelin
FRC #1165 (Team Paridise)
Dr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura about
Sprocket for Bike Chain...
My team wanted to use bike chains this year instead of the chains included in the KOP. I was wondering what teams have used bike chains and what sprockets and other hardware was used.
Thank you
ph.D Asskickanomics
Magnets work well
Thor Protector of Man kind
Raise your swords up high
See the black birds fly
Let them hear your rage
Show no fear
"Our Mini-bot goes 'clink-whee"
Unread 20-01-2012, 17:54
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Sprocket for Bike Chain...
I have not used bike chain, however I would encourage you to look into #25 chain which is similar in size but not compatible with bike chain.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 20-01-2012, 18:00
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
My team was very successful using bicycle chain on our arm last year. I went to a bike shop, got the shop to "sponsor" us and give us some old sprockets from their used parts pile. They come with holes for mounting, but no hub, so I cut aluminum disks to bolt onto the sprockets, them machined a hub to attach them to the axles.
I use machinable shaft collars from McMaster-Carr to make easy hubs. I bore them out to the shaft size, then drilled and tapped a couple of holes to attach to the disk I'd mounted the sprocket on.
Bicycle sprockets come in a large range of sizes, are much lighter than 25 or 35 size chain sprockets, are pretty strong (don't know how they would do on a drive system), and easy to come by.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 20-01-2012, 20:51
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I think the best place to get bike sprockets if off of old bicycles. It's cheap and good for the environment.
Just a word of warning. Some robotics hobbyists, who use bike chain, have noted that it derails more easily than normal chain. Which is good on your 20 speed bike but very very bad on your competition robot.
Unread 20-01-2012, 22:59
DonRotolo's Avatar
Back to humble
FRC #0832
#25 chain has about a 1/4" (0.25") pitch
#35 chain has about 3/8" pitch
Bicycle chain has 1/2" pitch. It is about the size of #35 but lighter.
Any of these have sufficient strength for what you're likely to do with it.
Bike sprockets come from bikes, but there are other 'sports' that use bike chain.
