Go to Post Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why. - CalTran [more]
Unread 20-01-2012, 20:53
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Post Particle Analysis Report Problems
I am trying to use camera tracking to track the reflective tape, but I am having problems with the frcParticleAnalysis function. I'm not sure how to use it. my code is:
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
Jaguar jag1;
Jaguar jag2;
Solenoid Sol1 ;
Joystick stick2;
HSLImage image;
ParticleAnalysisReport par;
BinaryImage image2;
public:
RobotDemo(void):
myRobot(1, 3, 2, 10), // front left, rear left, front right, rear right
stick(1), //these must be initialized in the same order
jag1(7),
jag2(8),
Sol1(8),
stick2(2)
myRobot.SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
myRobot.SetSafetyEnabled(false);
AxisCamera &camera = AxisCamera::GetInstance();
camera.WriteBrightness(0);
Wait(3.0);
myRobot.MecanumDrive_Cartesian(0.0, 0.0, 0.0, 0.0); // stop robot
while (!IsOperatorControl())
camera.GetImage();
frcParticleAnalysis(image2, 5, par); /*the error says "cannot convert 'BinaryImage' to 'Image*' for argument '1' to 'int frcParticleAnalysis (Image*, int, ParticleAnalysisReport*)'*/
* Runs the motors with single stick holonomic steering.
* comment
void OperatorControl(void)
while (IsOperatorControl())
myRobot.SetSafetyEnabled(true);
myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetThrottle(), 0); // drive with arcade style (use right stick)
if(stick.GetTrigger())
jag2.SetSpeed(.8);
jag1.SetSpeed(.5);
Wait(.2);
Sol1.Set(true);
if(stick2.GetTrigger())
jag1.SetSpeed(.5);
else
Sol1.Set(false);
jag1.SetSpeed(0);
jag2.SetSpeed(0);
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Love, Peace, and Robot Grease
Unread 20-01-2012, 22:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Particle Analysis Report Problems
You declare your variable image2 as a BinaryImage*, which is why the compiler is having trouble. It sees parameter 1's type as "BinaryImage*", but it is looking for Image*. Also, you don't assign anything out of your call to camera.GetImage(). It should be something like image2 = camera.GetImage() [except that might not be the right type. Check out AxisCamera.h to find out what GetImage() returns].
I don't have the code in front of me, but it is likely that what you need to do is do something like this:
ColorImage colorImage;
camera.getImage(&colorImage);
frcParticleAnalysis(&colorImage, 5, par);
However, we had success last night doing something different. We did something very similar to this. It is unlikely the code below or above will compile, it's coming out of memory.
ColorImage img;
camera.getImage(&img);
BinaryImage* binImg = img.ThresholdRGB(192,256,192,156,192,256);
vector<ParticleAnalysisReport>* particles = binImg->GetOrderedReport(); // I don't remember this function's actual name
for(int x = 0;x < particles.size(); x++)
ParticleAnalysisReport& par = (*particles)[x];
// do something with par: look at par.center_mass_x, par.center_mass_y, etc.
Unread 21-01-2012, 11:44
Cody Trey's Avatar
Could you please post you actual code when you come in? It looks really good and I'd really like for my team to have camera tracking this year. Thanks so much!
Unread 21-01-2012, 14:38
Cody Trey's Avatar
this is my autonomous code as it stands now. can you guys help me figure out what to do/where to go from here.
Wait(3.0);
/** ColorImage &colorImagel;
camera.GetImage(&colorImage);
frcParticleAnalysis(&colorImage, 5, par); **/
HSLImage img;
camera.GetImage(&img);
BinaryImage* binImg = img.ThresholdRGB(192, 256, 192, 156, 192, 256);
vector<ParticleAnalysisReport>* par = binImg->GetOrderedParticleAnalysisReports(); //warning: unused variable 'par'
for(int x = 0; x < 5/**par.x**/; x++)
ParticleAnalysisReport& par = (*particles)[x]; //error: 'particles' undeclared (first use this function)
int x;
par.center_mass_x = x;
//do something with particles: par.center_mass_x & par.center_mass_y
thanks for the help
Last edited by Cody Trey : 21-01-2012 at 14:39. Reason: for got to put a question...
Unread 21-01-2012, 15:35
Bongle's Avatar
		Wait(3.0);
			ColorImage img;
			vector<ParticleAnalysisReport>* particles = binImg->GetOrderedParticleAnalysisReports();
			for(UINT32 x = 0; x < particles->size(); x++)
				if(par.center_mass_x_normalized > 0) { /* turn right */ }
				else if(par.center_mass_x_normalized < 0) { /* turn left */ }
This should get you started. The robot centering will be kinda jerky once you put the turning calls into myRobot, but should mostly work.
If you're focused JUST on autonomous however, don't forget the physical approach: put an aiming device on the robot, and have your drive team place and aim the robot using that. That removes the need to use the camera at all, mostly. You wouldn't get aiming in teleoperation mode, but if the goal is just autonomous, you can achieve it with just an on-robot aimer. It's actually what we did last year.
Unread 21-01-2012, 16:26
Cody Trey's Avatar
awesome, well I have one more error to fix then I can just wait until electrical and mechanical have there stuff finished...
BinaryImage* binImg = img.TresholdRGB(192, 256,156, 192, 256); //error: request for member 'ThresholdRGB' in 'image', which is of non-class type 'ColorImage*'
do I need to make img in to an RGB imag rather than just a Color Image?
Unread 21-01-2012, 16:49
Bongle's Avatar
You need to make it not a pointer.
The declaration for ColorImage should be:
ColorImage img;
From the compiler error, it sounds like you have
ColorImage* img;
That would be a pointer, which is why you can't do
img.ThresholdRGB(...)
Unread 21-01-2012, 16:59
Cody Trey's Avatar
ok, when I do that i get
ColorImage img; //error: no matching function for call to 'ColorImgae::ColorImage()'
if you want I'll post the whole code as it stands now if you think it'll help
Unread 21-01-2012, 17:12
Bongle's Avatar
Whoops, I forgot that ColorImage doesn't have a default constructor.
I believe it is:
ColorImage img(IMAQ_RGB_IMAGE);
You'll have to take a look at the constructor for ColorImage. Click on it, hit f3, and see what enumeration it requires. Hit f3 of the enumeration type, and it should take you to a list of options. You want the RGB one. Unfortunately, I'm once again at home, so I don't have our code in front of me.
Unread 21-01-2012, 17:26
Cody Trey's Avatar
I believe it is:
the constructor is IMAQ_IMAGE_RGB but it works now thanks!
Unread 21-01-2012, 18:03
Bongle's Avatar
As I'm always saying to our students - code compiling doesn't mean the code works :-)
Unread 21-01-2012, 22:03
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
If you run into issues tracking with an RGB image, try using HSL instead.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 03-02-2012, 18:06
Cody Trey's Avatar
I know... I meant built right...
Now that I've finially had a chance to test the code, I'm getting errors when we try to run it.
<Code>-1074396120 ERROR: status = -1074396120 (0xBFF60428) Error counting particles: ...in GetNumberParticles() in C:/WindRiver/workspace/WPILib/Vision/BinaryImage.cpp at line 29
<Code>-1074396120 ERROR: status = -1074396120 (0xBFF60428) ImaqThreshold error: ...in ComputeThreshold() in C:/WindRiver/workspace/WPILib/Vision/ColorImage.cpp at line 37
what do they mean? and...
do you think using a different image type would help?
Unread 03-02-2012, 19:27
Bongle's Avatar
They're all probably related to the same error. You'd have to post the exact code you're using to call the ThresholdRGB function for me to have a clue.
Edit: the code I posted above that has the ThresholdRGB call has a problem. It should be
ThresholdRGB(192,256,192,256,192,256)
I put a 156 where 256 should have been.
Unread 03-02-2012, 19:43
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I'm going to comment only on this single correction about the 156 versus 256...
Threshold takes 8-bit numbers for its thresholds. 256 is **NOT** an 8-bit number. 8-bit numbers range from (unsigned) 0-255 or (signed) -127 to 128. If you are passing 256 into this routine, you are likely passing a ZERO or an invalid number based upon the way Threshold processes it or passes it to the imaq functions.
255 is a MAX number ....
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
