Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 20-01-2012, 18:04
Fishpaste108 Fishpaste108 is offline
FRC #3467
Fishpaste108 is an unknown quantity at this point
Unhappy FIRST tools not showing in WindRiver c++
I am running Windows 7 64 bit operating system and have installed WindRiver according the the manual in disk 1. Everything is up to date. I have uninstalled it and re installed WindRiver as well as its supporting software multiple times. Please help
This is a list of all the software i installed in the order i installed them:
NI Software for FRC 2012 from USB Key
FRC tools update
Windriver disk 1
Windriver disk 2
2012 WIPLib Update from first forge
Unread 20-01-2012, 21:45
FRC #3467
Re: FIRST tools not showing in WindRiver c++
It turns out my PATH variable was corrupted. If anyone else has this problem double check to make sure it has this text in it:
%SystemRoot%\system32;%SystemRoot%; %SystemRoot%\system32\wbem;
