Go to Post #TeamFrank - Libby K [more]
Unread 20-01-2012, 22:19
Maine951 Maine951 is offline
AKA: Daniel
FRC #0533 (PSIcotics)
Maine951 is an unknown quantity at this point
[R02] Need someone to clarify!
<R02> D. states, "any appendage may not extend more than 14 in. beyond the frame perimeter" Does this mean that using software to restrict a mechanism from operating past the 14" perimeter is not acceptable and will result in failed inspection? In other words, is it legal to have a mechanism that can extend say, 20 inches past the robot's boundaries but program it to limit the extension to only 14 in?
Unread 20-01-2012, 22:21
giantmidget31's Avatar
giantmidget31 giantmidget31 is offline
Eat robots, build waffles.
FRC #0555 (Montclair Robotics)
Team Role: Electrical
giantmidget31 is an unknown quantity at this point
Re: [R02] Need someone to clarify!
I think it means that you will pass inspection, but if your robot does it in a match, you will be penalized. This might be a question for the q&a, just to make sure.
Unread 20-01-2012, 22:25
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Yes this is allowed but you should be asked to demonstrate the function during inspection and the head ref will be told to watch for the possible penalty
Unread 20-01-2012, 22:33
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
If you have something that is capable of breaking the rule but is theoretically restricted by software, what I've seen done in past years is they'll put you on a list (and maybe put a special sticker on your robot), and the ref will pay special attention in a match.
Unread 21-01-2012, 11:59
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
I think as long as it doesn't go past, you'll be fine. But, as others have said, the refs can't quite be sure it didn't go past 14. If it can, they'll have to worry about it, becuase technically, you might've hit 15 and they coulnd't tell becuase you were on the field. It seems a little risky.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
