Go to Post I don't even consider FIRST to be an extracurricular anymore; it is a way of life. - Jaine Perotti [more]
Unread 20-01-2012, 22:34
bmesa123 bmesa123 is offline
AKA: Bianca Mesa
FRC #4118 (Roaring Riptide)
Team Role: Student
bmesa123 is an unknown quantity at this point
More than one Bumper?
For this year's competition, our robot's frame is designed with two levels (Like a sandwich).. One is the lowermost part of the frame at 28" by 38", about 4" from the ground. The second level is supported directly above the first level with the same dimensions. The rules state that the bumpers on the sides of our robot must be located between 2-10" from the bottom of our robot.
My question is, if the upper and lower levels have the same dimensions, and the upper level is located 10" or greater from the bottom level, will we need to make two sets of bumpers: one for between 2-10", and another for the section of the robot that exceeds 10" in height?
Unread 20-01-2012, 22:42
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: More than one Bumper?
Nope. One set of bumpers in the bumper zone is what you have to do.
No. Bumpers are only to be mounted between 2 and 10 inches from the ground, where the bumper zone is.
Also note that a 28" by 38" robot, if you aren't including bolt heads in that measurement, will most likely not fit in the sizing box, forcing you to rebuild your robot slightly smaller. Most teams design an inch undersize in any given direction to allow for bolt heads and other miscellaneous stuff like that.
Unread 20-01-2012, 23:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I completely agree. Design for 27"x37" max. If your bot is in any way not 'square' and the top leans a bit, it won't fit in the sizing box. Also, you need to account for bolt heads and so forth as well (though we typically size our bots 27x37 before accounting for bolt heads.)
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 21-01-2012, 11:01
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: More than one Bumper?
Minor protrusions(nuts, bolts, etc.), according to the rules, are allowed beyond the frame perimeter, so you can build close to the frame footprint dimensions if you need to. It is always a good idea to allow for out of square and robot rock to ensure you will pass inspection.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 21-01-2012, 11:12
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
This rule only holds true for defining the frame perimeter in regards to bumper design.
The entire robot, including bolt heads must still be able to fit within the 38"x28"x60" sizing box.
We've always built between 1/4" and 1" under dimension depending on the year, it makes sliding the robot in and out of the box so much easier.
-Dustin Benedict
Unread 22-01-2012, 19:16
AKA: Bianca Mesa
Team Role: Student
Advice well taken. Thanks!
Unread 22-01-2012, 20:00
nitneylion452's Avatar
AKA: Joe Lee
Last year we were a hair too long (about 1/8" - 1/16"). We were also over weight (though we anticipated this and had a contingency plan). Cutting your robot to fit in the box is not fun. Thankfully a team lent us a portable band saw and made it a lot easier for us. But still not fun. It took us all of Thursday to get everything running properly again.
Case in point, take an inch off in design.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 22-01-2012, 21:22
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
to reiterate everyone else points - when anyone asks how big the robot can be, the answer is always 27x37. The other numbers are never said. (The dimensions that must not be named)
Unread 23-01-2012, 08:57
Bianca,
I know it might be hard to filter out the answer from above posts. You must conform to the bumper rules in that only one actual bumper system can fit on your robot between the 2" and 10" above the floor. (the dimensions allow only 8" while a bumper that is correctly constructed will be at least 5" high) It is possible and legal however, for parts of your bumper system to mounted low and others to be mounted high as long as all of the rules for bumpers are followed. Specifically, the minimum 8" segment on either side of an exterior vertex and all bumper construction rules.
Unread 31-01-2012, 11:48
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
There is only one set of bumpers on the robot. The things that you mount higher/lower than those bumpers may look and act like bumpers, but they are not. As such, they need to be inside of the frame perimeter and not directly above/below the real bumpers.
Unread 31-01-2012, 13:36
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Since your upper frame is the same size as your lower frame, a bumper on the upper frame would actually be prohibited. At the start of the match, nothing other than the Bumper may be outside the frame perimeter ([G01]). The bumper on the upper frame may be functionally a bumper, but would not actually count as a Bumper for rule purposes ([R01-2], [R28-E] and [R29]).
So, anything that is not an official Bumper (even if it looks and functions like a bumper) counts as part of the main robot, is part of the 120 lbs limit (excluding battery), and must be inside the perimeter at the start of the match. After the start, a bumper-ish thing could be part of an appendage that may extend up to 14" past the perimeter.
[EDIT] Oops, I didn't notice the post by LinuxArchitect before I submitted my post. Sorry for the redundancy.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 31-01-2012, 14:07
George,
There may be nothing outside of the frame perimeter except bumpers in the bumper zone. All other devices whether they look like bumpers or not, and whether they are mounted in the bumper zone or not, are illegal. The only exception is one appendage that must be inside the frame perimeter while in the starting configuration.
Unread 31-01-2012, 14:14
AKA: George Boyce
Yeah, I think that is what I said.
But you're allowed more than one appendage; the rule just says only one at a time may be deployed.
Unread 31-01-2012, 17:58
GaryVoshol's Avatar
Cogito ergo arbitro
The non-Bumper bumpers also have to fit in the sizing box, and are counted in the weight of the Robot.
(since 2004)
