Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
Unread 20-01-2012, 23:07
AjFoster AjFoster is offline
Hydra Robotics - 2425
AKA: AJ
FRC #2425 (Hydra Robotics)
AjFoster is an unknown quantity at this point
Re: NI Vision Functions
Thanks so much for the tips - everything runs error-free now.
Would it be possible to see an example of convexHull() being properly called (for an image which I've already used an HSL threshold on)?
Aj Foster
Team 2425 - HYDRA Robotics
Hillsborough High School
Tampa, Florida
Unread 21-01-2012, 20:28
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Sure, here is an example of how I call it:
convexHull(binaryImage.image,binaryImage.image,1);
That will find the convex hull of binaryImage and put it in binaryImage
Unread 21-01-2012, 20:40
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
You may want to check out this post. They have wrapped it into the library as of today. http://www.chiefdelphi.com/forums/sh...d.php?t=100792
Unread 21-01-2012, 22:29
FRC #1700
Yeah, but there are still many many functions upwrapped
Unread 22-01-2012, 11:19
AKA: Brad
#0190 ( Gompei and the Herd)
What would you like to see? Please be specific.
Brad
Brad Miller
Robotics Resource Center
Unread 25-01-2012, 11:21
FRC #1700
Currently, the only other one I am using is imaqSubtractFn, but in an ideal world I would like to play with the edge detection and the detect lines functions. Also, I've rewritten a bunch of the stuff with the particle reports, to get more data and because the sorted vector is slow.
Unread 28-01-2012, 14:11
Adamsmasher23 Adamsmasher23 is offline
FRC #1646 (Precision Guessworks)
Adamsmasher23 is an unknown quantity at this point
Brad
We would like the Linear Averages function, so that we can calculate a hollowness score.
Unread 12-02-2012, 18:16
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Does anyone know if there is full documentation of the NIVision C functions anywhere to make this process easier?
Unread 13-02-2012, 07:13
Program Filles/National Instruments/Vision/Documentation.
Specifically, you should look at the CVI document.
Greg Mckaskle
Unread 13-02-2012, 14:02
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
http://www.chiefdelphi.com/forums/sh...4&postcount=14
