Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 21-01-2012, 00:15
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Re: Windriver Error 1
Originally Posted by Micah Chetrit View Post
Nice vid, but not useful for me, because the issue is with building, and I can't continue until I do the first build.
That is what I did. Any other ideas?
That is your issue. Once, in the side panel I rightclicked on my project, hit Copy, then clicked outside of it and pasted it as 2012_1.1
It turns out that when you do that, it uses the same build configuration as the old class, so it tries to get the .out from the old class instead of your new one.
Get it?
So what you have to do is do a simple copy paste inside of Windows Explorer (like My Documents or C:/ for example) and rename it through there. Then go to WindRiver and File->Import->Existing Projects->Find your workspace where you copied it and select it. Then it should work!
-Eagle Engineering 1138
