Go to Post I'll just be happy if they give us a great game. - Koko Ed [more]
Unread 20-01-2012, 11:00
ultradan's Avatar
ultradan ultradan is offline
Team #3550 Robotronics
FRC #3550 (Robotronics)
ultradan is an unknown quantity at this point
Question Battery connections
My students had suggested to use compression lug connector with heatshrink to connect power cable at the battery poles. I saw on previous years robots that many teams were using instead a mechanical lugs ground and then isolated them with electrical tape. Are both solutions viable for the competition ?
Unread 20-01-2012, 11:36
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: Battery connections
I think it may depend on the inspector, but in previous years they've wanted us to cover the entire connection (with tape or whatever material). The shrink tubing only covers the wire connection point, not the lugs on the Power Distribution Board.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 20-01-2012, 11:38
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The only rule on those connections is R03 A, which defines what can be attached the the battery without counting towards the robot weight:
the 12V battery and its associated half of the Anderson cable quick connect/disconnect pair (including no more than 12 in. of cable per leg, the associated cable lugs, connecting bolts, and insulation) and
We can break your question into two parts:
- First, what type of connector to use. Both types, if rated for the correct gauge wire and current specs, will certainly work. As an experiment, you can have your students hook them both up and look at the resistance between the wire and the terminal - any resistance there will cause a decrease (even though it's slight) in robot performance, as that resistance is consuming some of the battery power.
- Second, what type of insulation to use. Both electrical tape and heat shrink work great here, and are both sufficient for any insulation you need at terminals or between wire splices on the robot. Heat shrink tends to look a little nicer, which matters to some teams. Electrical tape is easier to remove, which is both a plus and a minus... if you think you'll need to get at whatever it's protecting, then it's great. If you don't, then having it peel off on you (for example, the end can peel up if it's repeatedly rubbed against something) is pretty bad (as it can lead to a short), and something you might need to watch for.
Unread 20-01-2012, 11:40
Mentor, LRI, MN RPC
- Bryce
Bryce, that depends on the size of your heat shrink. My team uses appropriately sized heat shrink that covers the wire and the entire terminal and associated hardware.
But you are correct - you need to have the entire connection covered. It's a safety thing... with our robots and tools primarily being made out of conductive materials, we do not want to short the batteries and deal with the ~500A current that will result.
Unread 20-01-2012, 18:21
imjessica's Avatar
imjessica imjessica is offline
AKA: Jessica
FRC #4159 (CardinalBotics)
Team Role: Electrical
imjessica is a jewel in the roughimjessica is a jewel in the roughimjessica is a jewel in the rough
hey do you guys think that for the battery connector is it enough just to crimp it? we also soldered it but thats not very stable, and we'd definitely be able to pull it out if it wasnt for the electrical tape. how do we make a stable battery connection?
SF CardinalBotics - Head of Electronics
Unread 20-01-2012, 18:25
Well... I've found that if you're going to use a crimp joint on the battery lugs, you want a vise to do the crimping if possible. The longer the handle on the vise, the better! (For the best quality of crimp, that is.)
There is also a bag of copper connections in the KOP; those can be used with the batteries. Make sure the wire is between the plates, then screw down as hard as possible.
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
That depends on what you mean by "Crimp". To connect to the terminals on the battery, take your wire and do the crimping (with a crimper) to connect a ring terminal to your wire. Now, take the ring terminal and put it up against the hole on the terminal on the battery (there is a hole in it if memory serves me) and bolt it, then cover with heatshrink or electrical tape (though heatshrink is preferable)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 20-01-2012, 20:23
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
You should only a crimped lug if you have a proper crimper for the size wire you are crimping, and they are expensive. Otherwise use the mechanical (screw) lugs. I suggest using a vice to hold the mechanical lug and a large screwdriver. Either way if you can move the wire in the lug it is not properly terminated and will cause a problem at the worst time.
Electrical tape or shrink tube is only used for insulation.
Unread 20-01-2012, 20:54
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Don't forget to put the heat shrink on the cable BEFORE you connect to the battery... Otherwise you have to disconnect the bolt then redo and shrink it
Unread 20-01-2012, 22:56
DonRotolo's Avatar
Back to humble
FRC #0832
You must use the right crimper for the crimp lug or you are risking failure.
To solder it, you need a lot more heat than it sounds like you are using. Also use rosin flux (Radio Shack sells it in atube). Soldering is a reasonable alternative to crimping, but try to avoid getting a lot of solder into the cable near the lug, because that makes the wire stiff and subject to breaking like solid wire.
No.
The first bit, use the right crimper, NOT a vise which flattens the lug.
The second bit, there is a torque specification from the manufacturer that gives optimal performance. Cranking down as much as you can will exceed that spec. However, it would be prudent to re-torque the screw often.
That being said, do what you want. But we are trying to steer you away from known ways of creating problems for yourself.
Unread 20-01-2012, 23:03
It's a lot faster and easier to remove the pin from the Anderson connector.
Unread 20-01-2012, 23:11
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
If you are set on crimping them, but do not have the money for a proper crimper, I would suggest that you contact an area electrical company to see if you could borrow theirs or have them crimp them for you.
Our team has done this in the past with much success!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 21-01-2012, 01:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I'm not a fan of using a vise either. I've done it, but I've never really liked doing it.
For reference, Home Depot has sold a crimper in the past for about $35 that works very nicely. It looks like a bolt cutter. It's not necessarily the one that meets the spec for Anderson SB50-compatible reeled or individual connectors, but it is sized for the #6 AWG crimp lugs that FIRST has provided (it has a #3 die, as well as a couple others).
By the way, FIRST provides the wrong size of crimp lugs for the battery—theirs are for a Ø0.250 in stud, when they should probably be for a Ø0.190 in or Ø5.00 mm stud to match the battery terminals. (Ø0.250 in is correct for the Bussmann 120 A circuit breaker, and Ø6.00 mm = Ø0.236 in ≈ Ø0.250 in is correct for the power distribution block.)
Also a good idea.
Unread 21-01-2012, 02:00
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
JW, is there any particular method that you've developed to use this? I usually lever a screwdriver in and then use a second screwdriver to pop it off the spring (if you can call it a spring), and I find it an incredibly tedious and annoying process.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 21-01-2012, 02:04
A medium flat screwdriver and a pair of small pliers. It's really easy.
Just make sure that you don't short the battery terminals by accident (e.g. with the pliers). That would end badly. (It may be a good practice to stick a battery plug in the opposite Anderson SB50 terminal, or disconnect it at the screw lug.)
