Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
Unread 20-01-2012, 22:51
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
Vision Tracking Lighting Idea
I just read the FRC PDF on the 2012 vision tracking system. It talks about different lighting techniques that I found useful, however I had a question that is open for talking through. Instead of using regular LED's around the camera for the retro reflective tape, why not use IR LED's? Digital cameras easily pick it up, however that does bring up the question of "making the camera blind" so it can only see IR waves. I think was wondering if this were possible since it would cut down on a ton of processing power for an image. What does every one else think?
PS: If you're wondering about edge detection in a language other than LV look up using a high-pass filter and a sobel gradient filter. These are used for the core of edge detection.
Unread 20-01-2012, 23:10
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Vision Tracking Lighting Idea
Using IR LEDs and an IR filter* over the lens sounds like a good idea. Note that visible LEDs tend to be brighter than IR LEDs, so experiment!
*These filters look black. Look on an IR remote control for an example. They allow IR though and block visible light. Many cameras have a filter that blocks IR light and allows visible through.
Unread 20-01-2012, 23:15
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
There one gotcha that you should test for first. Both CMOS and CCD based cameras are highly sensitive to IR and so they almost always contain a filter on them to block IR from their input. You should make certain the LEDs you choose can be seen by the camera at all before you take it too far.
-Mike
Unread 21-01-2012, 00:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you do a search, you will find several discussions in threads about IR and the webcam. Specifically, the webcams we have have an integrated film on the lens that is not removable. You will have to replace the lens of the camera to do any work with IR.
Unread 21-01-2012, 01:37
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
*cough*Kinect*cough*
Unread 21-01-2012, 03:09
thaagbe's Avatar
thaagbe thaagbe is offline
FRC #3045
thaagbe is an unknown quantity at this point
Could you elaborate on this? Like actually placing the kinect *ON* the robot and using its camera. If yes then could you please tell us how my friend and I want to program this into our robot. Thank You
Unread 21-01-2012, 03:19
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
I'd caution against using IR.
It may work in your shop or in practice, but the real headaches will occur when you go to competitions. Depending on the venue, arenas may have IR heavy lighting that may interfere with your own lighting.
I recommend using some very bright color instead. Same amount of work to get it working in software and less amount of work on hardware.
My $.02,
Jeremy G.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 21-01-2012, 04:12
So....the Kinect projects an Infrared "beam" into the scene and depending on which driver/SDK you use(OpenNI, libfreenect, Microsoft SDK), you can get the IR feed directly from the Kinect. This feed is basically a grayscale image that represents the intensity of the Infrared received by the Kinect. Cool things happen with retroflective material (like that used on the Rebound Rumble targets). As for putting the Kinect on the robot...I dunno...Y U NOT KNOW????!!!!!!!
Unread 21-01-2012, 05:44
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Yes, and it should be just as simple as plugging the Kinect into the USB port on your cRIO...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 21-01-2012, 12:52
Exactly. Should be cake. ;-)
Unread 22-01-2012, 21:17
alancop's Avatar
alancop alancop is offline
200mph club member
AKA: Alan Copeland
FRC #1716 (Redbird Robotics)
Team Role: Electrical
alancop is an unknown quantity at this point
You are allowed to put a laptop on your robot, so theoretically, you could put a kinect and a small netbook on your robot, then connect it to the bridge and run a labview VI to send the information to your cRio.
Or even just use one of these http://mbed.org/ on your robot, and use the USB host and Ethernet interface to talk to the cRio, that would be lighter, but much harder to accomplish.
