#226
Re: Banebots RS-775 Case Short
This is all very scary to read. We just ordered 4 of these motors. And where planing on using 2 on the robot.
Gonna have to test them out heavily before competition. Has anyone experimented with trying to fix the shorts? - Bochek |
#227
This is a pretty important point. Just isolating the motors won't fix all of the issues. These motors do get worse over time and will fail, regardless if they are shorted to your frame.
#228
I shipped two of the four defective ones received back to BaneBots. We are awaiting the replacements. Once we get them we will let you know the prognosis.
Let's hope the these motors can at minimum spin... I'd say it's pretty bad when you get a motor that can't even spin. I wouldn't doubt it was caused by poor packaging as our four 775's were shipped in a USPS small flat rate box. Also we have noticed over the years that BaneBots enjoys "throwing" components in small flate rate Priority mail boxes. If I recall they shipped our planetary gearboxes last year like this with no padding and the box was bulging because they barely fit. Poor quality control, long lead times (at least for us last year), and poor packaging. I don't blame anyone who has or is considering not using BaneBots as a robot part supplier. The same applies in the real world. |
#229
An RS-775 motor is Ø1.85 in. A USPS small flat rate box is for items up to 1.625 in thick. That leaves -0.113 in for padding on each side of the motor. Let's see if BaneBots owns up to the packaging error, and provides free (working!) replacements in a timely fashion. |
#230
WE got two 775s in and both of them are good. No signs of any defects.
#231
My kids followed your lead and did the same... We used 775's all last year and had zero issues till the offseason and offseason presentations. Its pretty embarrassing when your robot won't work in front of a sponsor who donates over ($5,000) a year due to case shorts... We fixed the issue by swapping to a new 775. Chris and others, 550's are some awesome motors and the cimulator/p60's are awesome as well. Don't rule out a supplier because of one issue, I know its a big issue but 550 are very good motors. -RC |
#232
A manufacturing issue resulting a large number of defective motors is understandable; it happens to every supplier at one point or another. But continuing to sell the defective products to teams a full year later is just unbelievable.
I am very happy that the 2012 parts utilization rules make building a high-performing robot without BaneBots products an option. |
#233
That's where I'm coming from
#234
The RS-775 motors have a know issue with a short to thr frame. The easy fix is to run 12v from terminal to frame. Do this independently from the other terminal. If there is indeed a short to the frame, it won't be after you do this process. We had this issue last year and shorted each terminal, independently, to the frame of the motor and ran those motors all season with no problem.
#236
We locked the motor and hooked it up to a 12V battery. The magic smoke was released approximately 0.5 seconds after stall, perhaps less.
#238
Do you happen to have a spare RS-550 laying around to test the same thing with?
#240
The 550 is 254 watts at stall and is much less massive than the 775-18. Read this thread: http://www.chiefdelphi.com/forums/sh...7&postcount=34 |
