Go to Post The magic is ALL in the mentors. - AdamHeard [more]
Unread 16-01-2012, 17:41
gmendel's Avatar
gmendel gmendel is offline
Engineer of Time
AKA: QuelleDommage, norcalgem
FRC #1458 (Red Ties)
gmendel is an unknown quantity at this point
Team 1458 Ball Roller Prototype
Our prototype for the ball collector on our robot for the 2012 Rebound Rumble game is finished! Check it out:
Click here to see the awesomness!
Made with PVC and surgical tubing, and narrarated by the Great and Powerful Ryan Fuller!
(I'm the one in the red sweatshirt btw)
Unread 16-01-2012, 17:44
Andrew Lawrence
Posts: n/a
Re: Team 1458 Ball Roller Prototype
Looks great! However, I have a few questions:
Where would you have that on your robot? (middle, very front, etc)
If it's in the very front, are you aware that those multiple pieces of surgical tubing count as multiple appendages extending out of the drive base?
For the sake of this really awesome ball roller, please double check that to make sure it's legal! I'd hate to have something so awesome rack up penalties for you every time you use it.
Unread 16-01-2012, 17:56
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
RO2:
D: any appendage may not extend more than 14 in. beyond the frame perimeter
Unless I'm missing something obvious here, please explain why:
a. each of those pieces of surgical tubing count as separate appendages,
b. you can't have multiple appendages that aren't extending past 14 inches.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 16-01-2012, 18:00
Andrew Lawrence
Posts: n/a
A) They are not connected, and therefore are considered separate when they extend beyond the frame perimeter.
B) I may have misunderstood, but I thought it doesn't matter the length of an appendage if multiple are out of the frame perimeter.
If What you said in B) is true, then I take back my original post, and will proceed to implement this design on our robot.
If not, then I'll go read the game rules another time. I'll probably do that anyways, since "A game rule a day keeps the robot inspector away!"
Unread 16-01-2012, 18:02
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
[G21]
Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time.
Violation: Foul for exceeding size allotments; Technical-Foul for continuous or repeated violations.
Blue box:
These appendages are intended for use in manipulating Basketballs and/or Bridges. A Robot may have multiple extension devices onboard, but only one may be deployed at a given time.
Jason
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
I see no reason why an inspector would count them as separate appendages. They aren't really extending, and if anything, the roller itself then becomes an appendage. In addition, i think it would just be cruel to consider those separate appendages.
Originally Posted by jason701802 View Post
[G21]
Blue box:
whoops completely forgot about that rule. I probably shouldn't post on CD so assertively when I'm sick
Unread 16-01-2012, 18:06
Andrew Lawrence
Posts: n/a
It's alright. Hope you feel better! It's not very productive to be sick in the middle of build season, you know.
Unread 16-01-2012, 18:20
As much as I agree with you, this has yet to be clarified by the GDC/Q&A, and until such time, it would good to keep a backup in mind.
Jason
Unread 16-01-2012, 18:25
Andrew Lawrence
Posts: n/a
I think I have a way to keep this "legal".
Get sets of surgical tubing and glue/zip-tie them together so they become one wide strand. Make 4 of these, and place each set 90 degrees apart from each other on the rotating rod. Each will count as one extending past the frame perimeter since they will be glued/zip-tied together, and only one set will be outside the frame perimeter at a time since they are 90 degrees apart from each other.
I don't see anything illegal with that, though like always, I could be wrong.
Unread 16-01-2012, 18:55
gmendel's Avatar
Engineer of Time
ATTN ALL:
Our chassis will be "C" shaped with our rolling mechanism situated on the inside of the "C", therefore having none of the parts extending from the outside of the chassis, looking sort of like this:
(X marks the spot)
==wheel===wheel===wheel==
==----------------\xxxxxx/
==-----------------\xxxx/
==------------------\xx/
==------------------/xx\ <-- Balls go this way
==-----------------/xxxx\
==----------------/xxxxxx\
==---------------/xxxxxxxx\
Cruddy ascii art is cruddy, lol.
I hope that answers any questions you had!
Unread 21-01-2012, 02:37
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
I was wondering what mechanism is driving the ball collecting device. Like what kind of motors you are using and if you are using a gear box.
Unread 21-01-2012, 03:07
Please do not state things like this as if you know they are fact. The only fact is that this is not true until you see it asked and answered in the Q&A.
Don't assume that you know what appendage is defined as.
Unread 21-01-2012, 08:26
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
For those who haven't seen it:
Originally Posted by Q&A, approx 12:52pm, 20 Jan 2012
There is no formal definition of appendage; however, a colloquial definition is "a subordinate part attached to something; an auxiliary part; addition" (courtesy of dictionary.com). To elaborate, an appendage is a contiguous assembly that may extend beyond the Frame Perimeter per Rule [G21].
emphasis mine. (Interpret as you will.)
Unread 22-01-2012, 20:10
gmendel's Avatar
Engineer of Time
We're using two Fisher Price motors, although it is reeeally over powered, so we will try and change that.
Also, everyone else, calm down about the technicalities. We are all trying our best to follow the rules, and if they break any, we will fix it. It's all part of the design process and is not something to get super worked up over. It's just a game
Check out our website! (made by me)
team1458.com
Unread 22-01-2012, 22:57
militaryrobot's Avatar
militaryrobot militaryrobot is offline
FRC #0647
militaryrobot is an unknown quantity at this point
Thumbs up Re: Team 1458 Ball Roller Prototype
Good design. Looks like it will work at any angle.
Our robot is less then two feet
