Go to Post They hit us, we hit them, it happens. Build your robots to take a hit and it doesn't matter. - Greg Needel [more]
Unread 21-01-2012, 03:13
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: 2012 Team Update 4
Originally Posted by linuxboy View Post
The Field Access Point has both 2.4Ghz and 5Ghz antennas (3 of each), so I imagine that before going to Operation Bondé, FIRST would try switching the frequency, in case the venue has a lot of 5 Ghz APs (I obviously don't know, but I think that Operation Bondé would be avoided if at all possible). Does anyone know about a regional last year that had an issue with too many APs that would cause FIRST to start sending better radios, or does it seem like they are preempting the problem?
I have a post from last year explaining the problem. The issue manifested at FLR and Florida, and matches couldn't be run until they were able to get the venues to shut down some of the APs.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 21-01-2012, 03:26
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Ah the memories (Actually more like AHHHHHHHH! THE MEMORIES! as they drag you off to the padded room in a straightjacket).
Unread 21-01-2012, 03:30
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
As stated above, this issue did occur in Florida last year. Considering that the regional is on UCF's campus, a campus with over 50,000 students, it's not a surprise that there was a lot of wifi in the area. Teams would spend over 5 minutes trying to connect to the field only to be told to try again next time because it was taking too long. Once a team did connect, however, their chances of being found the next time increased exponentially, at least that is what was explained to me. I believe that is why the problem only really occurred on Thursday, because by Friday everyone had been able to connect at least once. At our next regional the FTA wanted everyone to connect to the field at least once on Thursday whether or not they were inspected, probably for this reason.
www.sharkattack744.com
