Go to Post I HAVE IT PROGRAMMED!!!! Ive just been forbidden from testing it... they think ill make the bot explode. >.> - Got_POSTWAFFLE? [more]
Unread 21-01-2012, 10:11
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Re: Camera Feed at the Competition?
Based on the information provided in Team Update 4, I am going to assume that we can use the camera as is, in the default configuration that is outlined in the Getting Started guide.
If anyone knows whether the signal is degraded beyond what we see right now, please let me know. Thanks
Unread 21-01-2012, 11:24
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
The resolution of the camera feed depends on your settings, the field won't change those. The conditions will be different than in your shop, however FIRST does a pretty good job of ensuring that the WIFI at events is not plagued with interference (causing the camera feed to be choppy), because that would also cause robot communication to be choppy.
tl;dr You'll be fine with the settings you have now.
