Go to Post just remember, with power comes responsibility. - Mike Ciance [more]
Unread 21-01-2012, 10:07
ultradan's Avatar
ultradan ultradan is offline
Team #3550 Robotronics
FRC #3550 (Robotronics)
ultradan is an unknown quantity at this point
Re: Battery connections
Thanks everyone for all the suggestions. My team has decided to use a compression lug (bluedie374) COVERED WITH heatshrink tubing. The full pole connection will have to be isolated. Then we'll validate the electrical resistance (should not exceed milliohms), and then we'll do a pull strength test. The tool used for compression is taken from HomeDepot.
Unread 21-01-2012, 10:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've used this crimper with good results. The dies are not perfect and their sizes are weird and it flattens the hex a little and puts "wings" on the sides of the crimp, but it goes make a good solid connection.
Unread 21-01-2012, 19:25
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Crimp, solder with a blowtorch, repeat.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 21-01-2012, 19:45
DonRotolo's Avatar
Back to humble
FRC #0832
A proper crimp does not need solder; indeed, the 'right' crimp is made worse with solder.
That being said, a 'pretyty close' crimp can be improved with solder.
We have used the crimping die on these pliers with great success. Two students squeeze it shut, it does take some effort.
Unread 22-01-2012, 01:57
Originally Posted by slijin View Post
JW, is there any particular method that you've developed to use this? I usually lever a screwdriver in and then use a second screwdriver to pop it off the spring (if you can call it a spring), and I find it an incredibly tedious and annoying process.
I use a very small screwdriver or awl from the "contact" side of the connector to push/pull the spring out of the way, then pull the wire and pin out the other side. It's easy. I even used a paper clip once.
