Go to Post Any school official who isn't tickled pink by hundreds high school students, and teachers, and parents, and mentors spending their weekend celebrating STEM isn't a school official worth having. - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 21 votes, 4.62 average. Display Modes
Unread 20-01-2012, 18:08
Re: cRIO Image Download
If you are not using LabVIEW to program, you still must install the Tools from that USB stick.
So, the installation procedure for Java/C++ starts with:
  1. LabVIEW Install Only FRC Tools (LV USB stick from KOP)
  2. LabVIEW Install Only Driver Station Support (LV USB stick from KOP)
  3. Utilities (from online: http://joule.ni.com/nidu/cds/view/p/id/2262)
  4. Driver Station (optional):
    1. Driver Station (from online: http://joule.ni.com/nidu/cds/view/p/id/2263)
    2. Microsoft Kinect SDK (online:http://kinectforwindows.org)
    3. .NET Framework 4.0 - may already be installed (online: http://www.microsoft.com/download/en....aspx?id=17851)
    4. Kinect Kiosk (online: http://firstforge.wpi.edu/sf/frs/do/listReleases/projects.wpilib/frs.2012_frc_kinect_server)
If using C++
  1. Install Wind River DVD 1
  2. If you have a 64-bit OS, then install Wind River DVD 2
  3. FRC C++ Update (online: http://firstforge.wpi.edu/sf/frs/do/listReleases/projects.wpilib/frs.2012_update_for_c)
If using Java
  1. Install NetBeans (online: http://netbeans.org/downloads/index.html)
  2. FRC Java Update (online: http://firstforge.wpi.edu/sf/frs/do/listReleases/projects.wpilib/frs.2012_java_update_for_frc
Updates will come and go as the season progresses, so keep an eye out for future updates to the Updates at the bottom of this page:
http://www.usfirst.org/roboticsprogr...control-system
Unread 20-01-2012, 18:48
Gnome2013's Avatar
Gnome2013 Gnome2013 is offline
Gnomies
FRC #2013 (Cyber Gnomes)
Gnome2013 is an unknown quantity at this point
Originally Posted by JacobGH View Post
I'm really confused as to why this is so complicated? Currently my computer possesses the 2011 cRio Java image. I need the 2012 image. I clicked "install everything" on the Labiew USB (the credit card-shaped one) and it did not install a 2012 image on my computer. It didn't even install the cRio imaging tool - I had to download that from NI's website. The Utilities Update page states that the Java update requires a 2012 image to do an update, but I have the 2011..
Where can I get the 2012 cRio image for Java?
When you get the java update if you're using jave, you will automatically get it image that how we just fiqured it out.
Unread 21-01-2012, 10:07
JacobGH JacobGH is offline
FRC #1849
JacobGH is an unknown quantity at this point
[*]FRC Java Update (online: http://firstforge.wpi.edu/sf/frs/do/listReleases/projects.wpilib/frs.2012_java_update_for_frc)
When I click on this link I get a "page not found" error. What's wrong? I'm logged int.
Unread 21-01-2012, 11:03
FRC #1849
Ok, I finally figured it out, thought I don't think this could have been made more complicated if they tried. You're right that installing the Java Updates through netbeans (using the repository) placed the 2012_v48 in my cRio_Images folder. Now, when I try and re-image the cRio, I get:
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
What is causing that? I noticed that my cRio Imaging tool is numbered Version 2001.11.18. I installed the two updates from:
but the version number hasn't changed. What's going on?
Unread 22-01-2012, 01:30
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Originally Posted by ksanger View Post
As a side note I've been on two teams now. The first team was behind a business firewall. The current team operates within a school system. Neither enable us to go out to the internet and verify OS's, or product keys, or updates. We can download files and sneaker net them over. But registrations do not work. As I'm doing this from home my students are not available so we can teach them too. Perhaps its best as I've had it for tonight.
This is a very common problem that needs to be addressed. I've spent many hours at home with the Classmate and school's laptop doing exactly that over the past few years. All time that is taken away from actually working on the robot.
It's also tiring to have to search all over for pieces of a puzzle - updates here, patches there, kinex programs another place, and don't get them in the wrong order. I realize the distribution is prepared far in advance, but couldn't there be one official place to go with one step-by-step setup and all files downloaded from one place?
{edit} Actually, what Mark has provided is the best I've seen. His post should be made sticky or something so everyone will see it.{/edit}
This year is incrementally better than past years, but I'm still developing a callous from banging my head on the wall...
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 25-01-2012, 20:33
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
All - what is the latest cRio image version as of 1-25-2012. I just want to make sure the latest is installed when I check it tommorrow. I think it has 4.3 right now.
Does the "utilties version 2.0" update include a new image?
Brian
Brian K
Team 1225 Robotics Mentor
Unread 25-01-2012, 21:04
v43
The new Utilities 2.0 Update doesn't contain a cRIO image.
Unread 23-01-2013, 22:20
mikemcd mikemcd is offline
FRC #4791
mikemcd is an unknown quantity at this point
As a new team this year with no help, this particular step has been draining for everyone. I can't begin to tell you how annoying it is to have pieces of updates spread out everywhere. This has truly taken away from the fun & excitement of the project....
Unread 23-01-2013, 22:28
FRC #1849
I totally agree. I was new last year and experienced the same drain that you're feeling now. FRC's software setup is horrendous and I would love to fix it.
In the meantime - have you finally figured it out? We'd be happy to help you through the forum.
Unread 23-01-2013, 22:29
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
Keep in mind, this thread is from last season.
http://www.usfirst.org/roboticsprogr...ical-Resources has links to all the updates that you need.
We'll be more than happy to help you out with any problems, just ask.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
