Go to Post Hyper, I want to marry your robot. - Keys [more]
Unread 21-01-2012, 11:24
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: Camera Feed at the Competition?
The resolution of the camera feed depends on your settings, the field won't change those. The conditions will be different than in your shop, however FIRST does a pretty good job of ensuring that the WIFI at events is not plagued with interference (causing the camera feed to be choppy), because that would also cause robot communication to be choppy.
tl;dr You'll be fine with the settings you have now.
