Go to Post Team Titanium's trying Teeter Totter Talons tying the terrain traversal tandoming Twin Tucking Tabs to try triples. - [more]
Unread 20-01-2012, 20:43
Peggy Painter Peggy Painter is offline
Catalyst
FRC #5476 (Y Bridge 4H Robotics)
Peggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud ofPeggy Painter has much to be proud of
How do we use the lift kit????
We got the Andymark lift kit but are having trouble figuring out how to use it.
Does it go on without modification? How?
I can't find any instructions directly related to it's use.
Thanks for your help.
Unread 20-01-2012, 21:01
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: How do we use the lift kit????
attached the wheels on the bottom and the robot on the top...
scared for you team...
cole?
Unread 20-01-2012, 21:02
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
It was given to everyone in the 2010 KOP, here is a pic:
Unread 21-01-2012, 00:32
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I strongly suggest bracing these things, they can cause the frame to flex enough to allow a stretched (through normal use) 35 chain jump off of the sprockets. Probably less of an issue this year than it was in 2010, the bump is much smaller, but it is also much more vertical.
Unread 21-01-2012, 09:02
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The flex and twist in the frame came less from the bump and more from the quick change in direction or turning of the robot. Diagonal bracing from the pods to the frame are a must if you wish to keep your chains on the sprockets.
Hi!
Unread 21-01-2012, 11:18
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
This year's bumper rules aren't going to play nice with those. Consider that in your design before you move forward.
Unread 21-01-2012, 11:46
GaryVoshol's Avatar
Cogito ergo arbitro
Can you explain why? Do they lift the frame more than 10" off the floor?
(since 2004)
Unread 21-01-2012, 12:04
Catalyst
Thanks for the suggestions....the photo is great. We really appreciate the help.
Unread 21-01-2012, 13:20
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
Well, those look like 6 inch wheels, the bumper zone is from 2 to 10 inches, and bumpers are 5 inches tall. I suppose they could be secured at only the top of the frame, I just don't consider that to be very ideal. I think some bracing at the midpoint of those lifts would allow for a stronger frame, more secure bumpers, and you could drop the board in there for a better cog.
