Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 21-01-2012, 12:26
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Lifting robot off the ground
Our team wants to know if we can push the robot up to meet the bridge when getting over it. We want to use the weight of the robot to our advantage when balancing.
I know there is a rule about the vertical projecction but does this fall into that category?
Unread 21-01-2012, 12:31
EricH EricH is online now
Re: Lifting robot off the ground
You mean the 84" maximum when not contacting alliance zone carpet (which is valid on the bridge)? Or do you mean the bumper zone rulings on Q&A/TU#4?
Last I've checked, there are no restrictions on using appendages, either in the 14" horizontal allowance or in the vertical allowances, to touch the ground from the bridge. (There are restrictions on whether leaving said appendages touching the ground results in a balanced bridge.)
Unread 21-01-2012, 12:40
Johnny_5's Avatar
AKA: Isaac
There is a rule about the vertical projection of the robot. I didn't know if having a pnuematic cylinder lift the robot up count for breaking the vertical projection
Unread 21-01-2012, 12:42
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Post Re: Lifting robot off the ground
On your side of the field you are aloud to be 84 in tall; if you are touching the oposite aliance carpet you can only be 60 in tall. See rule [R02].
Unread 21-01-2012, 12:50
There is a rule about the vertical projection: 60" tall to start or on your alliance station side of the field, or 84" tall on your offensive side.
You may be thinking of the 14" horizontal limit for appendages.
Unread 21-01-2012, 15:10
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
The rule in question here I believe is the bumper zone limits. The bumpers always have to be within the 2-10 inch zone, in reference to the carpet if that's what you're in contact with. If you lift your robot up, you would be out of the bumper zone and illegal, at least according to my interpretation.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 21-01-2012, 16:30
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Originally Posted by legogeek24 View Post
...... If you lift your robot up, you would be out of the bumper zone and illegal, at least according to my interpretation.
Does your interpretation take into consideration the latest revision of [R01-2]?
Unread 21-01-2012, 18:35
legogeek24's Avatar
AKA: Dirk
I hadn't seen that update when I replied. I believe the intent is to allow temporary exemption from the bumper zone requirements while crossing the bridge and bump. Lifting up a robot would seem to be legal if actively crossing the bridge or bump, or lining up to do so. Is that how you see it?
"1...2...3562!!!"
Unread 21-01-2012, 21:11
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
I am thinking the bumper rule is going to be key here. Keep the bottom of the bumper less than 10in above the flat surface?
Software Mentor
3853 Pridetronics[
Unread 22-01-2012, 17:34
legogeek24's Avatar
AKA: Dirk
I believe that the bumper rule must be met always in relation to a flat surface (the carpet, keys, and bridge according to the manual), but will be temporarily exempted if a robot is actively crossing the bridge or bump. The wording still seems to leave it open to interpretation though, there's no definite answer yet I don't believe.
"1...2...3562!!!"
Unread 22-01-2012, 18:45
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We're also considering the use of pneumatics to lift the robot. Not for getting on the bridge, but to brace it on level ground. As long as max height requirements and bumper zones are met it should be cool.
