Go to Post It is not for any other team to say what is beyond a person's or a team's capabilities. That's why they have mentors :-) - preussrobotics [more]
Unread 21-01-2012, 10:37
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
5mm pitch HTD belt in Design Accelerator
I'm having trouble finding 5mm pitch HTD timing belt in the Design Accelerator (using Inventor 2012). Does it just not exist?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 21-01-2012, 12:44
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: 5mm pitch HTD belt in Design Accelerator
the belt generator also only gives me max of 260XL37 belt, but we are getting 524XL037 from gates, is inventor DA just that restrictive, or am I doing it wrong?
i'm using 2011 'cause school didn't feel like updating this year. if 2012 has more selection, i can use our team computer
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 21-01-2012, 13:04
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
2012 doesn't have a better selection.
We just designed a drive train using this belt. If you can explain a little more what you're trying to do I can help you out.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 21-01-2012, 13:14
joek's Avatar
trying to make a preliminary mock-up of our ball lifter, making it between 2 50 tooth gears, using a 37 mil wide XL belt. the longest I hcan find is 130 teeth, but I need 262 teeth
Unread 21-01-2012, 15:44
FirstUpdatesNow.com
Did you use Inventor? What's your belt length?
@jmontois340
Team 3015
Unread 21-01-2012, 15:56
joek's Avatar
i mean in inventor, i need a 52.4" belt
Unread 22-01-2012, 14:53
Ninja_Bait's Avatar
AKA: Jake Potter
Is no one going to answer my question?
I don't really have a problem with the fact that my thread has been hijacked, I'd just like to have an answer.
Unread 22-01-2012, 19:26
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
I am checking the specifications of the belts you have requested against the Gates information. Some possibilities,
1. Create the belt with Design Accelerator using the closest match. Then modify the Inventor paramaters to match the Gates parameters.
2. Use the data from Gates and then model the belt as a part. You have the length, sprocket diameters etc. So I think this is doable.
Will try to get back to you tomorrow.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 22-01-2012, 20:22
FirstUpdatesNow.com
52.4 inches seems to be in a deadband in Gates belts.
Can you adjust that length in your design? Add a snub pulley?
@jmontois340
Team 3015
