Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 21-01-2012, 13:37
atmega168 atmega168 is offline
FRC #0612
atmega168 is an unknown quantity at this point
Lightbulb PHUE - Targeting System
I have designed a ring of LEDS using rebel's
Designed to use 3 of each RGB LEDS this shield receives +12v and connects like a servo. The Signal controls the HUE of the output of the shield.
The retro reflective tape on the vision targets then fire the light back the same angle it came in, IE the camera lenses.
We found purple and green to work well.
A version using only 3 LEDS will be offered as well.
Images from the Camera with the 3 LED version will be up soon.
Before I start production, of this, I want to test the waters of who is interested. time 2-3 weeks.
Please let me know. And if you have a In house fab for PCBs, let me know then we can cut time and costs
So who is interested!
Unread 21-01-2012, 23:48
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: PHUE - Targeting System
I think Andy Mark also offers a 12V green LED ring light that you can purchase with FIRST credit. I believe it has 15 LEDs.
Unread 22-01-2012, 12:03
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
The only Rebel lights I'm familiar with are from Phillips and don't come in RGB to my knowledge:
http://www.philipslumileds.com/produ...on-rebel-color
Did I miss the RGB variant?
We might be willing to buy the design and code but not the production board itself as it will take too long and we can build it in house with a pcb router and solder the vias. A couple of questions:
How powerful of LEDs will it drive?
How many bits of PWM are you using? This dictates how well you can dim and color control the LED at the same time.
Are you using HSB or something simpler?
Yup, it's a nice little ringlight. BUT, the AndyMark ringlight is NOT powerful enough in our teams opinion - we've already tested it pretty heavily. We got superb results for a little distance (10-15 feet) but the noise in the image had to increase a lot by the time we got to 20-30 feet. We are shooting for 40-50 feet of good image quality/edge detection in a bad lighting environment so we can have some confidence of it working well in actual competition. It's not that we expect to shoot that far but we do expect imaging to be working consistently and this means good, controlled, lights are critical.
-Mike
Unread 22-01-2012, 14:12
The "3 of each RGB LEDS" is a little misleading. It means 3 each of red, green, and blue.
Unread 22-01-2012, 20:26
FRC #0612
I update to a new version using 3 1-Red 1-Green 1-Blue Rebel LEDS
This reduces cost greatly and still has a great range.
The key to the design working is the proximity of the leds to the lenses.
Andy marks is pretty far away from the center of the lens.
The signal will be a standard Digital Servo PWM.
That is 1.25-2 ms High 20 ms pulse length.
It will be scaled along the 360 Color wheel to control HUE.
So 1.25 = Red
1.5 = Green
1.75 Blue
2.0 = RED
A simple modification to any servo library will fix this.
Otherwise the code can scale it along the standard 1.25-1.75 timing,
But I would like green to be the "HOME" position.
