Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 18-01-2012, 19:52
TEAM1100soft506 TEAM1100soft506 is offline
The runaway renegade of 1100
AKA: Connor Moroney
FRC #1100 (The T-hawks)
TEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these parts
Question Netbeans stops working on inspiron 1100 after installing wpilibj
I installed netbeans on my windows seven running dell inspiron 1100 laptop. then i installed the wpilibj modules. after that, netbeans no longer works. any ideas?
EX Team member and mentor of TEAM 1100!!! The T-hawks!!!
Finalists WPI regional 2011 along with 177 2011
Winners of the engineering excellence award at Boston Regional 2011
WPI regional 2013 Chairmans award winners
Now the runaway renegade.
Unread 18-01-2012, 20:05
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Re: Netbeans stops working on inspiron 1100 after installing wpilibj
Try with Eclipse.. It's a much much better IDE.
Unread 18-01-2012, 20:20
AKA: Connor Moroney
My team uses netbeans i am fimilliar with netbeans. i dont want to learn something new right now. can i get help getting netbeans working.
Unread 19-01-2012, 03:04
AKA: Brad
#0190 ( Gompei and the Herd)
What's not working? Can you describe what's happening?
Brad
Brad Miller
Robotics Resource Center
Unread 19-01-2012, 07:47
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
What version of Netbeans? During beta testing the manual said that any version later than 6.7 would work, and 6.9.1 was recommended (IIRC). But the first one I tried did not install the plugins properly and 6.9.1 worked fine. You might consider trying 6.9.1 if you are not currently. I have not had any problems with it so far.
Good luck!
Unread 19-01-2012, 16:32
AKA: Connor Moroney
Good luck!
It is 7.1 the latest.
Brad
Netbeans opens, goes through the whole startup process, and then when it should be opening the ide window to code in, it just dies, no error message nothing, it is as if it was never started. it functioned fully before i installed the library then afterwords, it just loads the window where it initalizes, runs through that, then there is nothing at all, no ide no trace of it in task manager, no log file, nothing at all.
Unread 19-01-2012, 23:28
AKA: Jim O'Malley
From the install guide:
NetBeans IDE version 6.7 or later (there may be issues running NetBeans V7, please install V6.9.1 until we’ve had a
chance to review this).
I checked our notes, we had trouble with 6.7.1 and 7.1.
Unread 20-01-2012, 08:35
AKA: Connor Moroney
so use 6.9.1 and my life will be better?
Unread 20-01-2012, 09:42
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Yeah, probably. That's what we did.
Unread 20-01-2012, 16:40
AKA: Connor Moroney
no good. it did not work any other ideas
Unread 21-01-2012, 09:03
AKA: Jim O'Malley
For clarity is this what you did:
un-install of the previous version of netbeans, rebooted
installed 6.9.1
added plug-in info, downloaded & installed all FRC plugins
restarted the IDE
(because you are going backwards it is important to completely remove the previous version)
And you still see the same symptoms as the 7.1 install?
I have working versions (dev environment only) on XP, Vista, 7, and Ubuntu 10.04. So I am mystified.
Unread 21-01-2012, 09:06
AKA: Jim O'Malley
When you say "no log file" did you also check the windows system logs?
Unread 21-01-2012, 10:37
AKA: Connor Moroney
installed 6.9.1
restarted the IDE
Not quite, i first tried it with with 7.1 twice, once on a unclean installation of seven, once on a brand new installation of seven, and then with 6.9.1 on an clean new installation of seven, each time with the same results, and the same procedure.
i checked the netbeans log after i made the original post with the help of my mentor and found this.
>Log Session: Friday, January 20, 2012 6:03:22 PM EST
>System Info:
Product Version = NetBeans IDE 6.9.1 (Build 201007282301) (#3acac80d2b13)
Operating System = Windows 7 version 6.1 running on x86
Java; VM; Vendor = 1.6.0_25; Java HotSpot(TM) Client VM 20.0-b11; Sun Microsystems Inc.
Runtime = Java(TM) SE Runtime Environment 1.6.0_25-b06
Java Home = C:\Program Files\Java\jdk1.6.0_25\jre
System Locale; Encoding = en_US (nb); Cp1252
Home Directory = C:\Users\Connor Moroney
Current Directory = C:\Program Files\NetBeans 6.9.1
User Directory = C:\Users\Connor Moroney\.netbeans\6.9
Installation = C:\Program Files\NetBeans 6.9.1\nb
C:\Program Files\NetBeans 6.9.1\ide
C:\Program Files\NetBeans 6.9.1\java
C:\Program Files\NetBeans 6.9.1\apisupport
C:\Program Files\NetBeans 6.9.1\websvccommon
C:\Program Files\NetBeans 6.9.1\profiler
C:\Program Files\NetBeans 6.9.1\harness
C:\Program Files\NetBeans 6.9.1\platform
Boot & Ext. Classpath = C:\Program Files\Java\jdk1.6.0_25\jre\lib\resources.jar;C:\Pr ogram Files\Java\jdk1.6.0_25\jre\lib\rt.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\sunrsasign.jar;C:\P rogram Files\Java\jdk1.6.0_25\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\jce.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\charsets.jar;C:\Pro gram Files\Java\jdk1.6.0_25\jre\lib\modules\jdk.boot.ja r;C:\Program Files\Java\jdk1.6.0_25\jre\classes;C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\dnsns.jar;C:\Pr ogram Files\Java\jdk1.6.0_25\jre\lib\ext\localedata.jar; C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunjce_provider .jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunmscapi.jar;C :\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunpkcs11.jar
Application Classpath = C:\Program Files\NetBeans 6.9.1\platform\lib\boot.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-modules.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-util-lookup.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-util.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\boot_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\boot_pt_BR.jar;C:\Progra m Files\NetBeans 6.9.1\platform\lib\locale\boot_zh_CN.jar;C:\Progra m Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_zh_CN.jar;C:\Program Files\Java\jdk1.6.0_25\lib\dt.jar;C:\Program Files\Java\jdk1.6.0_25\lib\tools.jar
Startup Classpath = C:\Program Files\NetBeans 6.9.1\platform\core\core.jar;C:\Program Files\NetBeans 6.9.1\platform\core\org-openide-filesystems.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\core_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\core_pt_BR.jar;C:\Progr am Files\NetBeans 6.9.1\platform\core\locale\core_zh_CN.jar;C:\Progr am Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\nb\core\org-netbeans-upgrader.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_ja.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_ja.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_zh_CN.jar
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module edu.wpi.first.squawksdk: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module edu.wpi.first.wpilibj.templates: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.renamerefactoring: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.SPOTFRCwelcomemodule: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.sunspotfrcapplicationtemplate: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: the modules [edu.wpi.first.squawksdk, edu.wpi.first.wpilibj.templates, org.netbeans.modules.autoupdate.pluginimporter, org.netbeans.modules.beans, org.netbeans.modules.bugtracking, org.netbeans.modules.bugtracking.bridge, org.netbeans.modules.bugzilla, org.netbeans.modules.db.sql.editor, org.netbeans.modules.dbschema, org.netbeans.modules.debugger.jpda, org.netbeans.modules.debugger.jpda.ui, org.netbeans.modules.deployment.deviceanywhere, org.netbeans.modules.deployment.wm, org.netbeans.modules.derby, org.netbeans.modules.diff, org.netbeans.modules.editor.bracesmatching, org.netbeans.modules.editor.codetemplates, org.netbeans.modules.editor.indent.project, org.netbeans.modules.editor.macros, org.netbeans.modules.form, org.netbeans.modules.form.j2ee, org.netbeans.modules.glassfish.common, org.netbeans.modules.glassfish.javaee, org.netbeans.modules.hibernate, org.netbeans.modules.hibernateweb, org.netbeans.modules.i18n, org.netbeans.modules.i18n.form, org.netbeans.modules.identity.profile.ui, org.netbeans.modules.identity.server.manager, org.netbeans.modules.j2ee.common, org.netbeans.modules.j2ee.ddloaders, org.netbeans.modules.j2ee.ejbcore, org.netbeans.modules.j2ee.jboss4, org.netbeans.modules.j2ee.jpa.verification, org.netbeans.modules.j2ee.persistence, org.netbeans.modules.j2ee.samples, org.netbeans.modules.j2ee.sun.appsrv, org.netbeans.modules.j2ee.sun.appsrv81, org.netbeans.modules.j2ee.sun.ddui, org.netbeans.modules.j2ee.weblogic9, org.netbeans.modules.j2eeserver, org.netbeans.modules.j2me.cdc.platform, org.netbeans.modules.j2me.cdc.platform.semc, org.netbeans.modules.j2me.cdc.project, org.netbeans.modules.j2me.cdc.project.nokiaS80, org.netbeans.modules.j2me.cdc.project.nsicom, org.netbeans.modules.j2me.cdc.project.ojec, org.netbeans.modules.j2me.cdc.project.ricoh, org.netbeans.modules.j2me.cdc.project.savaje, org.netbeans.modules.j2me.cdc.project.semc, org.netbeans.modules.j2me.cdc.project.sjmc, org.netbeans.modules.java.examples, org.netbeans.modules.java.j2seproject, org.netbeans.modules.java.navigation, org.netbeans.modules.java.project, org.netbeans.modules.javadoc, org.netbeans.modules.javascript.editing, org.netbeans.modules.javascript.hints, org.netbeans.modules.javawebstart, org.netbeans.modules.jumpto, org.netbeans.modules.kenai.ui, org.netbeans.modules.localhistory, org.netbeans.modules.maven, org.netbeans.modules.maven.grammar, org.netbeans.modules.maven.graph, org.netbeans.modules.maven.hints, org.netbeans.modules.maven.j2ee, org.netbeans.modules.maven.jaxws, org.netbeans.modules.maven.repository, org.netbeans.modules.maven.search, org.netbeans.modules.mercurial, org.netbeans.modules.mobility.deployment.ftpscp, org.netbeans.modules.mobility.deployment.ricoh, org.netbeans.modules.mobility.deployment.webdav, org.netbeans.modules.mobility.end2end, org.netbeans.modules.mobility.jsr172, org.netbeans.modules.mobility.project, org.netbeans.modules.mobility.svgcore, org.netbeans.modules.options.editor, org.netbeans.modules.properties, org.netbeans.modules.refactoring.api, org.netbeans.modules.registration, org.netbeans.modules.server, org.netbeans.modules.spring.beans, org.netbeans.modules.subversion, org.netbeans.modules.swingapp, org.netbeans.modules.terminal, org.netbeans.modules.tomcat5, org.netbeans.modules.versioning, org.netbeans.modules.versioning.system.cvss, org.netbeans.modules.versioning.util, org.netbeans.modules.vmd.componentssupport, org.netbeans.modules.vmd.game, org.netbeans.modules.vmd.inspector, org.netbeans.modules.vmd.midp, org.netbeans.modules.vmd.midp.converter, org.netbeans.modules.vmd.midpnb, org.netbeans.modules.vmd.model, org.netbeans.modules.vmd.palette, org.netbeans.modules.web.beans, org.netbeans.modules.web.client.tools.api, org.netbeans.modules.web.freeform, org.netbeans.modules.web.project, org.netbeans.modules.websvc.core, org.netbeans.modules.websvc.customization, org.netbeans.modules.websvc.design, org.netbeans.modules.websvc.manager, org.netbeans.modules.websvc.metro.model, org.netbeans.modules.websvc.metro.samples, org.netbeans.modules.websvc.restapi, org.netbeans.modules.websvc.saas.codegen, org.netbeans.modules.websvc.saas.services.strikeir on, org.netbeans.modules.websvc.saas.ui, org.netbeans.modules.websvc.utilities, org.netbeans.modules.websvc.wsitconf, org.netbeans.modules.xml, org.netbeans.modules.xml.jaxb, org.netbeans.modules.xml.tools.java, org.netbeans.spi.editor.hints, org.sunspotworld.SPOTFRCwelcomemodule, org.sunspotworld.sunspotfrcapplicationtemplate] use org.jdesktop.layout which is deprecated: Use javax.swing.GroupLayout instead. (In form editor: select Form ... in Inspector; change Layout Generation Style to Standard Java 6 code.)
WARNING [org.netbeans.core.projects.cache]: layer jar:file:/C:/Users/Connor%20Moroney/.netbeans/6.9/modules/edu-wpi-first-wpilibj-templates.jar!/edu/wpi/first/wpilibj/templates/layer.xml contains duplicate folders named Templates/Project/Samples/FRC Java
Could not open SDK Home: C:\Users\Connor Moroney\SunSPOTFRC
java.lang.OutOfMemoryError: Java heap space
at org.netbeans.JarClassLoader$JarSource.resource(Jar ClassLoader.java:543)
at org.netbeans.Archive.getData(Archive.java:199)
at org.netbeans.JarClassLoader$JarSource.doGetResourc e(JarClassLoader.java:504)
at org.netbeans.JarClassLoader$Source.getResource(Jar ClassLoader.java:337)
at org.netbeans.JarClassLoader.findResource(JarClassL oader.java:272)
at org.netbeans.ProxyClassLoader.getResource(ProxyCla ssLoader.java:375)
at org.netbeans.core.startup.NbResourceStreamHandler$ Connection.connect(NbResourceStreamHandler.java:11 4)
at org.netbeans.core.startup.NbResourceStreamHandler$ Connection.getInputStream(NbResourceStreamHandler. java:202)
at java.net.URL.openStream(URL.java:1010)
at edu.wpi.first.squawksdk.Installer.isSdkCurrent(Ins taller.java:130)
at edu.wpi.first.squawksdk.Installer.startRoutine(Ins taller.java:53)
at edu.wpi.first.squawksdk.Installer.restored(Install er.java:42)
at org.netbeans.core.startup.NbInstaller.loadCode(NbI nstaller.java:426)
at org.netbeans.core.startup.NbInstaller.load(NbInsta ller.java:366)
at org.netbeans.ModuleManager.enable(ModuleManager.ja va:944)
at org.netbeans.core.startup.ModuleList.installNew(Mo duleList.java:318)
at org.netbeans.core.startup.ModuleList.trigger(Modul eList.java:254)
at org.netbeans.core.startup.ModuleSystem.restore(Mod uleSystem.java:286)
at org.netbeans.core.startup.Main.getModuleSystem(Mai n.java:172)
at org.netbeans.core.startup.Main.start(Main.java:302 )
at org.netbeans.core.startup.TopThreadGroup.run(TopTh readGroup.java:114)
at java.lang.Thread.run(Thread.java:662)
is this useful to helping to fix the problem?
Unread 21-01-2012, 13:51
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
I am also having difficulties with Netbeans and this years plugins.
Tried both 6.7.1 and 7.1 on Dell D600 XP with 512M
At first I thought this was a memory issues so I added more memory (1 Gb).
No luck. We are using a desktop which loaded NB and this years plugins. This will not work at the competition.
I have tried so many combinations and wasting a great deal of time.
I am very frustrated with this software this year and do not know where to go for assistance.
Dave Frederick Manassas VA Team 1895.
Unread 21-01-2012, 14:13
FRC #1895
Looks like Netbeans 6.9.1 works.
It installed on one laptop with 1Gb memory with the FRC modules.
