Go to Post now now, there is no such thing as reading the manual too much. I read it every night just before I go to bed. - 663.keith [more]
Unread 21-01-2012, 14:31
4AngryNutjobs's Avatar
4AngryNutjobs 4AngryNutjobs is offline
FRC #3859
4AngryNutjobs is an unknown quantity at this point
[FTC]: Wireless connection
Our progrmmers are in a bind. We have established our controller and robot in Labview. We have also uploaded our wifi info onto the samanthe module. We are stuck getting this thing wireless. I should add, we are able to contoll the bot with the NXT brick connected via USB. How do we get this to work via Samantha?
Unread 21-01-2012, 22:33
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
Re: [FTC]: Wireless connection
If you want to control your robot over Wi-Fi, the best option would be to install the FMS software that FTC releases here. They also have some great videos on how to set this up and how to connect your robot.
Hope this works! Let me know if you have any other problems!
Karan Hiremath
FTC Team 110- MFS Foxes
Facebook: MFS Foxes
YouTube: MFS Foxes
Twitter:
@Foxes_110
Co-Captain
Head Programmer
Service Coordinator
Builder
Electrical
Unread 22-01-2012, 10:19
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
You can also control the robot using WiFi using the Remote Control tab in LabVIEW for LEGO Mindstorms.
Note: Once our programs got sufficiently large, the Run Program in FTC mode within the LabVIEW Remote control didn't always give predicatble results.
We needed to switch back and forward between developing/downloading with Labview -- and -- using the FCS to run a match.
Also note, you can't have two programs connected to the NXT through the Samantha at the same time. So it's either LabVIEW or FCS, but not both. Once it's connected, LabVIEW holds onto the connection until it's completely closed, so it can be a bit frustrating switching back and forwards all the time.
Phil Malone
http://www.GEARSinc.org
Unread 23-01-2012, 00:17
AKA: Karan Hiremath
Ah there is the ability to use Wi-Fi in LabVIEW now? How does it perform? Unfortunately I use RobotC mostly so I haven't seen that feature yet! Good to know!
Karan Hiremath
Facebook: MFS Foxes
YouTube: MFS Foxes
Twitter:
@Foxes_110
Co-Captain
Head Programmer
Service Coordinator
Builder
Electrical
Unread 23-01-2012, 09:24
PhilBot's Avatar
AKA: Phil Malone
WiFi for downloading is wonderfull (no cable plug/unplug or Bluetooth).
Switching between labview and FCS is a pain to test Auto Mode, so we added a touch sensor to the robot that overrides the FCS for testing purposes.
Download new auto code via wifi, press touch sensor to run it, or use FCS for real timing.
Phil Malone
