Go to Post Don't trust everything you read on Chief Delphi. - Peter Matteson [more]
Unread 21-01-2012, 11:24
DPErny DPErny is offline
FRC #4316
DPErny is an unknown quantity at this point
Help with Tank Drive
Hello, all! I'm the programmer from a rookie team. I've never used Labview before. I'm trying to change our drive system to Tank Drive.
When I follow the default instructions for tank drive, only one joystick responds, and that joystick turns both motors, instead of each joystick turning one.
I have no idea why this is happening or how to fix it, and I'm at the end of my Google-fu abilities.
Unread 21-01-2012, 11:44
Re: Help with Tank Drive
What instructions are you following? Can you post your code?
Unread 21-01-2012, 14:19
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
did you initialize 2 in the Begin vi, each with a different usb and different name?
Unread 21-01-2012, 14:36
FRC #4316
This was the problem. I hadn't known to initialize the second joystick.
Unread 21-01-2012, 14:38
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
do you want a screen shot of how to do it?
Unread 21-01-2012, 14:41
Mara's Avatar
Mara Mara is offline
Team 696 Safety Czar
FRC #0696 (Circuit Breakers)
Mara has a little shameless behaviour in the past
Make sure both joysticks are plugged in. You'd be surprised to know how many times our programming team has had troubles because of wires not being connected.
