Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
Unread 21-01-2012, 13:46
seinchin seinchin is offline
AKA: Kevin
FRC #4144 (Semi-Con-Duck-tors)
seinchin is an unknown quantity at this point
2012 Fisher Price motors with GEM gearbox
Does anybody know if the Fisher Price motors included in the 2012 Rookie KOP (with pinion attached) will fit in the AndyMark GEM gearbox (am-0449)?
Unread 21-01-2012, 14:18
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: 2012 Fisher Price motors with GEM gearbox
I don't believe it will. The pinion on the FP motor has a DP (Diametric Pitch) of 32.
AndyMark's website says its internal gears are 20 DP.
http://www.andymark.com/product-p/am-0449.htm
ALSO: The sun gear for the GEM is 15T, while the pinion is 13T.
Unread 21-01-2012, 14:40
Chris is me's Avatar
AKA: Pinecone
If you want to use an FP with the GEM gearbox, you'd need to use the CIM-SIM or the AM Planetary to "convert" the gearbox output to a CIM.
Unread 21-01-2012, 14:45
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I imagine you could actually do something similar to the AM Planetary conversion. Buy the right sun gear to press onto the FP and make a mounting plate that will give you the CIM's bolt holes. Unless there is some limitation on speed or torque you can input into the GEM, I don't see why this kind of thing isn't possible.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 21-01-2012, 14:46
AKA: Pinecone
The AM Planetary output is the CIM input size. Since the AM Planetary has the same ratio, why wouldn't you use that?
Unread 21-01-2012, 14:51
Ninja_Bait's Avatar
AKA: Jake Potter
Angry Re: 2012 Fisher Price motors with GEM gearbox
This is certainly a valid method, but not useful if you don't want to convert your FP to a CIM, i.e. you want to use the GEM directly with the speeds and torques that the FP normally outputs, not something geared to replicate a CIM.
Same ratio as what? If you wanted to use the 3.67:1 ratio of a GEM 500 gearbox with an FP, it wouldn't be very helpful to put an AM Planetary in between (now you have ~10:1 ratio).
Last edited by Ninja_Bait : 21-01-2012 at 14:52. Reason: dropped a period... also, I don't know how I got that angry face up there. Please disregard, because I'm not angry.
Unread 21-01-2012, 14:57
AKA: Pinecone
The AM Planetary also has a 3.67:1 ratio. Different gear sizing, same reduction.
Unread 21-01-2012, 15:02
Ninja_Bait's Avatar
AKA: Jake Potter
Oh, I see what you mean.
I think the OP needs to tell us why the GEM is being considered...
Unread 21-01-2012, 15:32
AKA: Kevin
We would like to gear the FP down to ~5000 rpm for use in a shooter. The AM planetary has the same reduction as the GEM -- unfortunately, it's currently out of stock.
