Go to Post Incidentally, the best Delphi is ChiefDelphi! :) - Max Lobovsky [more]
  #226   Spotlight this post!
Unread 20-01-2012, 20:32
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: Banebots RS-775 Case Short
This is all very scary to read. We just ordered 4 of these motors. And where planing on using 2 on the robot.
Gonna have to test them out heavily before competition.
Has anyone experimented with trying to fix the shorts?
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
  #227   Spotlight this post!
Unread 20-01-2012, 20:37
Originally Posted by Dale(294engr] View Post
(theoretical remedy: electrically isolate each motor to pass inspection, but problem will likely escalate as more turns shorted draws higher current & produces less torque; high localized heating leads to catastrophic smoke)
This is a pretty important point. Just isolating the motors won't fix all of the issues. These motors do get worse over time and will fail, regardless if they are shorted to your frame.
  #228   Spotlight this post!
Unread 21-01-2012, 01:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I shipped two of the four defective ones received back to BaneBots. We are awaiting the replacements. Once we get them we will let you know the prognosis.
Let's hope the these motors can at minimum spin...
I'd say it's pretty bad when you get a motor that can't even spin. I wouldn't doubt it was caused by poor packaging as our four 775's were shipped in a USPS small flat rate box.
Also we have noticed over the years that BaneBots enjoys "throwing" components in small flate rate Priority mail boxes. If I recall they shipped our planetary gearboxes last year like this with no padding and the box was bulging because they barely fit.
Poor quality control, long lead times (at least for us last year), and poor packaging. I don't blame anyone who has or is considering not using BaneBots as a robot part supplier. The same applies in the real world.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
  #229   Spotlight this post!
Unread 21-01-2012, 01:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Brilliant work, BaneBots. You've obviously figured out how to make a shipping box larger on the inside than on the outside.
An RS-775 motor is Ø1.85 in. A USPS small flat rate box is for items up to 1.625 in thick. That leaves -0.113 in for padding on each side of the motor.
Let's see if BaneBots owns up to the packaging error, and provides free (working!) replacements in a timely fashion.
  #230   Spotlight this post!
Unread 21-01-2012, 02:11
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
WE got two 775s in and both of them are good. No signs of any defects.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
  #231   Spotlight this post!
Unread 21-01-2012, 02:28
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by Karthik View Post
Four brand new motors arrived today. All shorted. I'd call this the first sign of trouble...
http://desmond.yfrog.com/Himg736/sca...=640&ysize=640
We will not be using any RS-775 motors this year.
We ordered 2 775's and 15 550's. 550's were all good, both 775's were bad. We are definitely not using 775's this year.
My kids followed your lead and did the same...
We used 775's all last year and had zero issues till the offseason and offseason presentations. Its pretty embarrassing when your robot won't work in front of a sponsor who donates over ($5,000) a year due to case shorts... We fixed the issue by swapping to a new 775.
Chris and others, 550's are some awesome motors and the cimulator/p60's are awesome as well. Don't rule out a supplier because of one issue, I know its a big issue but 550 are very good motors.
-RC
R.C.
MadTown Robotics Team 1323
  #232   Spotlight this post!
Unread 21-01-2012, 09:42
Jared Russell's Avatar
Taking a year (mostly) off
A manufacturing issue resulting a large number of defective motors is understandable; it happens to every supplier at one point or another. But continuing to sell the defective products to teams a full year later is just unbelievable.
I am very happy that the 2012 parts utilization rules make building a high-performing robot without BaneBots products an option.
  #233   Spotlight this post!
Unread 21-01-2012, 10:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's where I'm coming from
  #234   Spotlight this post!
Unread 21-01-2012, 13:43
at the first sign of trouble they'll be introduced to our arbor press.
Instead of crushing them, could I talk you into frying them instead? Hook them up to 12 volts and let us know how long it takes to release the factory smoke. That might be a useful bit of data for folks who are considering using them on drivetrain.
  #235   Spotlight this post!
Unread 21-01-2012, 15:24
Mrpalmere Mrpalmere is offline
Chief 1/2 bot builder
#1089 (Team Mercury)
Mrpalmere will become famous soon enoughMrpalmere will become famous soon enough
The RS-775 motors have a know issue with a short to thr frame. The easy fix is to run 12v from terminal to frame. Do this independently from the other terminal. If there is indeed a short to the frame, it won't be after you do this process. We had this issue last year and shorted each terminal, independently, to the frame of the motor and ran those motors all season with no problem.
  #236   Spotlight this post!
Unread 21-01-2012, 15:48
I'm sure you meant "applied 12 volts between" instead of "shorted".
  #237   Spotlight this post!
Unread 21-01-2012, 15:59
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
We locked the motor and hooked it up to a 12V battery. The magic smoke was released approximately 0.5 seconds after stall, perhaps less.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #238   Spotlight this post!
Unread 21-01-2012, 16:13
Thank you.
  #239   Spotlight this post!
Unread 21-01-2012, 16:36
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Do you happen to have a spare RS-550 laying around to test the same thing with?
Attending: MN Duluth Regional
  #240   Spotlight this post!
Unread 21-01-2012, 16:45
The 775-18 is 273 watts at stall at 12 volts.
The 550 is 254 watts at stall and is much less massive than the 775-18.
Read this thread:
http://www.chiefdelphi.com/forums/sh...7&postcount=34
