Go to Post Welcome to FIRST! You will soon figure out that there is no "exit strategy" from this program. - David Brinza [more]
Unread 21-01-2012, 13:16
l0stboy l0stboy is offline
FRC #4064 (InZombiacs)
l0stboy is an unknown quantity at this point
BuiltInDefaultCode stays stuck while running
My team has successfully made our control system and imaged our cRIO. Before, the program wouldn't run because we forgot to put in our team number into NetBeans. That took care of all the error messages that we were getting, but now the program stops while running. The progress bar at the botton stays at the same location. Any ideas on what could be the problem?
Pedro
Ocala InZombiacs
Unread 21-01-2012, 16:08
AKA: Brad
#0190 ( Gompei and the Herd)
Re: BuiltInDefaultCode stays stuck while running
Do you mean that Netbeans stops running? Can you post the messages that came out of the Netbeans console log up until it stopped?
Brad
Brad Miller
Robotics Resource Center
Unread 22-01-2012, 18:39
Spex_guy's Avatar
Spex_guy Spex_guy is offline
Java Master
AKA: Martin Wickham
FRC #2220
Spex_guy is an unknown quantity at this point
Our team had some problems like this. Make sure your cRIO is updated and that it can get through your firewall.
while(attempt() != succeed);
If at first you don't succeed, try again.
