Go to Post The driver must have a relationship with the robot, the driver should talk to the robot, speak soft encouraging words to it. Pet names are also a good idea. If the driver does not love the robot, how can the driver learn to trust the robot. - Gboehm [more]
  #91   Spotlight this post!
Unread 20-01-2012, 11:03
Re: CIM Motor Sacrifice
Originally Posted by Aur0r4 View Post
@Ether
Perhaps I am wrong (and there's always an opportunity to learn) but we went through the specs last year and we were unable to find anything that showed that the 18V version running at 2/3 the nominal voltage performed better than the RS-550 at nominal.
Here's the specs for the 775-18 operating at 12 volts:
M7-RS775-18-AT12V.pdf
  #92   Spotlight this post!
Unread 20-01-2012, 11:37
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
We are considering this
AM Planetary with 2011 Fisher Price KOP Motor Installed (am-0822)
Performance Data:
Input voltage: 12 volts
Stall Torque: 1.4 ft-lb
Free speed: 5500 rpm
http://www.andymark.com/product-p/am-0822.htm
Specs are really close to a regular CIM motor
  #93   Spotlight this post!
Unread 21-01-2012, 12:45
magicole's Avatar
magicole magicole is offline
FRC #1566
magicole is an unknown quantity at this point
Originally Posted by Garrett.d.w View Post
Back to OP, this year we are placing a BB 775 with a CIMulator gearbox in places where a CIM would be normally used.
You could do this on your drivetrain or anywhere else really. If you are going to build a ball pitcher, I would use the 775s and keep the more powerful CIMs for drive.
this is a great idea. hopefully it will keep our weight and power consumption down.
  #94   Spotlight this post!
Unread 21-01-2012, 16:07
Some numbers to consider:
CIM stalled at 60* amps generates ~325 watts of waste heat
775-18 stalled at 60* amps generates ~500 watts of waste heat.
Has anyone run a test to see how long a 775-18 can be stalled at 60 amps before it smokes?
EDIT: see this post: http://www.chiefdelphi.com/forums/sh...&postcount=237
*per the datasheet, 40 amp MX5 can sustain 60 amp for up to 47 seconds
  #95   Spotlight this post!
Unread 21-01-2012, 16:20
Mara's Avatar
Mara Mara is offline
Team 696 Safety Czar
FRC #0696 (Circuit Breakers)
Mara has a little shameless behaviour in the past
Our team believes that four CIM's is essential for our drive train. We need our most powerful motors to get over the bump. We'll be using some other motor for our shooter. Perhaps a bane bots or fisher price.
