Go to Post As for Dave and the stairs, just ignore him like the rest of the FRC GDC does... ;) - Rich Kressly [more]
  #61   Spotlight this post!
Unread 11-01-2012, 02:21
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Let's Talk About The Bridge:
Originally Posted by Marc S. View Post
See the rule updates, all robots must be touching the ramp to be supported by the ramp. So now you just have to build a robot that can lift itself high enough to allow a robot to fit underneath. Maybe some team collaboration is needed.
.......any Robots touching it are fully supported by it.”
I am not sure that the new update precludes robot on robot. The bottom robot is touching the ramp and it is supported by the ramp. It doesn't matter that there is another robot on top of it.
However, one could also argue that the upper robot must be supported by the ramp by default since it is on a robot completely supported by the ramp.
Hmmmm seems more clarification is needed here for sure.
  #62   Spotlight this post!
Unread 11-01-2012, 02:36
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
I would say the intent of the rules doesn't preclude robot on robots, but that's just my interpretation. It's hard to believe the GDC wouldn't want you to get points for balancing robots like that, unless you're trying to use it as a loophole of sorts so you could touch the ground or something.
  #63   Spotlight this post!
Unread 11-01-2012, 23:01
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Originally Posted by Djur View Post
There actually is a metal bracket on the edge to prevent robots from driving off; it's about 1 inch high if I remember right.
2" angle stock as per the drawings
  #64   Spotlight this post!
Unread 12-01-2012, 00:09
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Completely unrelated to all of the posts in this thread so far, but I have a new question:
Do these measurements seem accurate?
If not, are they close enough that it doesn't really matter?
  #65   Spotlight this post!
Unread 12-01-2012, 00:52
Chinoman27 Chinoman27 is offline
FRC #1388
Chinoman27 is an unknown quantity at this point
OUr team was mulling over an idea like this. Two non driven wheels with no interaction with the drive train are on the end of a rotating arm of sorts. THis arm is left horizontal at the base of the robot within all wheels and bumpers while drivng. When robot is approaching the bridge the arm is pushed down, pushing the wheels onto the ground lifting the front end of the robot off the ground high enough to place front wheels on bridge. Back wheels can still drive robot forward to get front wheels over bridge edge. Then the arm is pulled back and the robots weight pulls the bridge down with the front wheels already on and alternate wheels stowed back below.
  #66   Spotlight this post!
Unread 12-01-2012, 11:03
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by Ninja_Bait View Post
Interesting question. G27 prevents you from doing it on the coopertition bridge:
But not with your own alliance partners. Hmmm....
Hmm...<G27> prevents contacting opposing robots within their frame perimeter. Any rule about the bumpers?
  #67   Spotlight this post!
Unread 12-01-2012, 13:38
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Originally Posted by davidthefat View Post
Personally, I want to take all the human aspects out of the balancing. The operators are facing them head on, not to the side of the board. So my plan is to get all the alliance members up and tell them to drop all controls so the software can do its work.
I don't follow... you're expecting each alliance partner to have such software and that it is compatible? That would be taking coopertition to a new level.
  #68   Spotlight this post!
Unread 12-01-2012, 14:01
AKA: George Boyce
You're expected to make contact within the bumper zone. Normally to push an opponent, but pulling/pushing a partner even with the aid of a mechanism would seem ok to me.
IMHO, each robot should have a bumper grabber to aid in bridge balancing by latching on to their neighbor. You have a pretty good (but not perfect) idea where your partner's bumper will be so it shouldn't be too difficult. Perhaps not a top priority though.
  #69   Spotlight this post!
Unread 12-01-2012, 17:25
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Why not save your arm idea the stress of lifting a 140 pound fully loaded robot and just push the bridge down in the front?
  #70   Spotlight this post!
Unread 12-01-2012, 18:15
noceradave noceradave is offline
FRC #1279 (Cold Fusion,Bulldogs)
noceradave is a glorious beacon of lightnoceradave is a glorious beacon of lightnoceradave is a glorious beacon of lightnoceradave is a glorious beacon of lightnoceradave is a glorious beacon of light
the center of gravity of your own robots's a counterweight
  #71   Spotlight this post!
Unread 12-01-2012, 18:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Based on the calcs that I have done (from the info the video provides plus the other data from the rules, etc.),
  • at level, it takes about 15lbs at the edge to tip to an empty bridge
  • the bridge must weigh about 200lbs and it's CG must below 9" above the barrier top or else their would be zero restoration torque when down - I estimate it is at 7" FWIW
  • If two robots with their combined CG on the centerline of the bridge (and they weigh 143 lbs each), it takes 35lbs to push the edge of the bridge down and their combined CG can move +/-5” without tipping the bridge. If one robot is stationary, the other robot can move +/-10”!
  • Further, assuming each has a CG 20” above the plane of the top of the bridge and they are in their nominal balance position, if the bridge is tipped to the ground, it will take 39lbs at the edge of the ramp to lift them back up.
  • Continuing… if they move from their together from their nominal position, they will have to move more than 6” up the ramp to make the bridge neutrally balanced (+ a bit more to get it to move). Note that this is beyond the 5" they have from nominal (see above) and they then have to stop the bridge so they will have to move maybe 3" back once they start tipping.
  • If only one robot does the rebalancing, they will have to move 12" up the ramp ...
I could go on, but this is all physics guys…
There's a lot to think about... ...fun fun fun...
Joe J.
Team #88, TJ2
  #72   Spotlight this post!
Unread 13-01-2012, 01:26
AKA: Chris
FRC #0599 (Robodox)
Thanks for the analysis Joe....
Do we know exactly how far the Bridge edge is from the wall. We have it at around 1 inch. Can anyone confirm this from taking measurements from the actual demo field?
  #73   Spotlight this post!
Unread 21-01-2012, 16:38
rscheer rscheer is offline
FRC #4206
rscheer is an unknown quantity at this point
Does anyone have the wieght of a battery handy?
  #74   Spotlight this post!
Unread 21-01-2012, 16:43
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
IIRC, they're ~15 lbs
Edit: looking it up, they're 6.2 kilograms = 13.6686603 pounds (from the datasheet)
  #75   Spotlight this post!
Unread 21-01-2012, 23:45
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
[Semi-teaser] Once you realize that getting FOUR full size robots on the bridge is quite possible without them overlapping, then the ways for easily getting three on and balanced start to look a lot easier to accomplish.
-RRLedford
