Go to Post Be afraid. Be very, very, graciously afraid. - Rich Kressly [more]
Unread 21-01-2012, 16:49
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Bridge mode?
There is several discussions on communication with the crio due to offloadinf tthe vision processing.
Would that work (wifi and/or Ethernet) with bridge mode as bridge mode is used in competition
Unread 21-01-2012, 16:56
Re: Bridge mode?
The ports that will be open on the field WiFi network are in yesterday's team update
Unread 22-01-2012, 00:11
What about onboard? Anything about Ethernet?
Unread 22-01-2012, 09:54
Re: Bridge mode?
If both devices are on-board there is a rule that tells you a narrow range of ports to avoid
