Go to Post If you ever find yourself thinking that you are the most brilliant person in a situation, you are doing something wrong. - EricVanWyk [more]
Unread 21-01-2012, 16:47
TEAM1100soft506 TEAM1100soft506 is offline
The runaway renegade of 1100
AKA: Connor Moroney
FRC #1100 (The T-hawks)
TEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these parts
Re: Netbeans stops working on inspiron 1100 after installing wpilibj
Originally Posted by omalleyj View Post
When you say "no log file" did you also check the windows system logs?
what i mean is that the windows log is not there but there is a netbeans log file that i will post at the very end of this message.
For clarity is this what you did:
un-install of the previous version of netbeans, rebooted
installed 6.9.1
added plug-in info, downloaded & installed all FRC plugins
restarted the IDE
(because you are going backwards it is important to completely remove the previous version)
And you still see the same symptoms as the 7.1 install?
I have working versions (dev environment only) on XP, Vista, 7, and Ubuntu 10.04. So I am mystified.
yes i do see the same symptoms ans in the 7.1 install. fresh install of 7 and a old install of seven
Originally Posted by DaveFrederick View Post
Looks like Netbeans 6.9.1 works.
It installed on one laptop with 1Gb memory with the FRC modules.
i am happy it worked for you, but it did not for me.
>Log Session: Friday, January 20, 2012 6:03:22 PM EST
>System Info:
Product Version = NetBeans IDE 6.9.1 (Build 201007282301) (#3acac80d2b13)
Operating System = Windows 7 version 6.1 running on x86
Java; VM; Vendor = 1.6.0_25; Java HotSpot(TM) Client VM 20.0-b11; Sun Microsystems Inc.
Runtime = Java(TM) SE Runtime Environment 1.6.0_25-b06
Java Home = C:\Program Files\Java\jdk1.6.0_25\jre
System Locale; Encoding = en_US (nb); Cp1252
Home Directory = C:\Users\Connor Moroney
Current Directory = C:\Program Files\NetBeans 6.9.1
User Directory = C:\Users\Connor Moroney\.netbeans\6.9
Installation = C:\Program Files\NetBeans 6.9.1\nb
C:\Program Files\NetBeans 6.9.1\ide
C:\Program Files\NetBeans 6.9.1\java
C:\Program Files\NetBeans 6.9.1\apisupport
C:\Program Files\NetBeans 6.9.1\websvccommon
C:\Program Files\NetBeans 6.9.1\profiler
C:\Program Files\NetBeans 6.9.1\harness
C:\Program Files\NetBeans 6.9.1\platform
Boot & Ext. Classpath = C:\Program Files\Java\jdk1.6.0_25\jre\lib\resources.jar;C:\Pr ogram Files\Java\jdk1.6.0_25\jre\lib\rt.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\sunrsasign.jar;C:\P rogram Files\Java\jdk1.6.0_25\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\jce.jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\charsets.jar;C:\Pro gram Files\Java\jdk1.6.0_25\jre\lib\modules\jdk.boot.ja r;C:\Program Files\Java\jdk1.6.0_25\jre\classes;C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\dnsns.jar;C:\Pr ogram Files\Java\jdk1.6.0_25\jre\lib\ext\localedata.jar; C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunjce_provider .jar;C:\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunmscapi.jar;C :\Program Files\Java\jdk1.6.0_25\jre\lib\ext\sunpkcs11.jar
Application Classpath = C:\Program Files\NetBeans 6.9.1\platform\lib\boot.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-modules.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-util-lookup.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\org-openide-util.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\boot_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\boot_pt_BR.jar;C:\Progra m Files\NetBeans 6.9.1\platform\lib\locale\boot_zh_CN.jar;C:\Progra m Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-modules_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util-lookup_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\lib\locale\org-openide-util_zh_CN.jar;C:\Program Files\Java\jdk1.6.0_25\lib\dt.jar;C:\Program Files\Java\jdk1.6.0_25\lib\tools.jar
Startup Classpath = C:\Program Files\NetBeans 6.9.1\platform\core\core.jar;C:\Program Files\NetBeans 6.9.1\platform\core\org-openide-filesystems.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\core_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\core_pt_BR.jar;C:\Progr am Files\NetBeans 6.9.1\platform\core\locale\core_zh_CN.jar;C:\Progr am Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_ja.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\platform\core\locale\org-openide-filesystems_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\nb\core\org-netbeans-upgrader.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_ja.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\core_nb_zh_CN.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_ja.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_pt_BR.jar;C:\Program Files\NetBeans 6.9.1\nb\core\locale\org-netbeans-upgrader_zh_CN.jar
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module edu.wpi.first.squawksdk: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module edu.wpi.first.wpilibj.templates: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.renamerefactoring: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.SPOTFRCwelcomemodule: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: had to upgrade dependencies for module org.sunspotworld.sunspotfrcapplicationtemplate: added = [module org.openide.util.lookup > 8.0] removed = []; details: [#170056: Separate module for Lookup API]
WARNING [org.netbeans.core.modules]: the modules [edu.wpi.first.squawksdk, edu.wpi.first.wpilibj.templates, org.netbeans.modules.autoupdate.pluginimporter, org.netbeans.modules.beans, org.netbeans.modules.bugtracking, org.netbeans.modules.bugtracking.bridge, org.netbeans.modules.bugzilla, org.netbeans.modules.db.sql.editor, org.netbeans.modules.dbschema, org.netbeans.modules.debugger.jpda, org.netbeans.modules.debugger.jpda.ui, org.netbeans.modules.deployment.deviceanywhere, org.netbeans.modules.deployment.wm, org.netbeans.modules.derby, org.netbeans.modules.diff, org.netbeans.modules.editor.bracesmatching, org.netbeans.modules.editor.codetemplates, org.netbeans.modules.editor.indent.project, org.netbeans.modules.editor.macros, org.netbeans.modules.form, org.netbeans.modules.form.j2ee, org.netbeans.modules.glassfish.common, org.netbeans.modules.glassfish.javaee, org.netbeans.modules.hibernate, org.netbeans.modules.hibernateweb, org.netbeans.modules.i18n, org.netbeans.modules.i18n.form, org.netbeans.modules.identity.profile.ui, org.netbeans.modules.identity.server.manager, org.netbeans.modules.j2ee.common, org.netbeans.modules.j2ee.ddloaders, org.netbeans.modules.j2ee.ejbcore, org.netbeans.modules.j2ee.jboss4, org.netbeans.modules.j2ee.jpa.verification, org.netbeans.modules.j2ee.persistence, org.netbeans.modules.j2ee.samples, org.netbeans.modules.j2ee.sun.appsrv, org.netbeans.modules.j2ee.sun.appsrv81, org.netbeans.modules.j2ee.sun.ddui, org.netbeans.modules.j2ee.weblogic9, org.netbeans.modules.j2eeserver, org.netbeans.modules.j2me.cdc.platform, org.netbeans.modules.j2me.cdc.platform.semc, org.netbeans.modules.j2me.cdc.project, org.netbeans.modules.j2me.cdc.project.nokiaS80, org.netbeans.modules.j2me.cdc.project.nsicom, org.netbeans.modules.j2me.cdc.project.ojec, org.netbeans.modules.j2me.cdc.project.ricoh, org.netbeans.modules.j2me.cdc.project.savaje, org.netbeans.modules.j2me.cdc.project.semc, org.netbeans.modules.j2me.cdc.project.sjmc, org.netbeans.modules.java.examples, org.netbeans.modules.java.j2seproject, org.netbeans.modules.java.navigation, org.netbeans.modules.java.project, org.netbeans.modules.javadoc, org.netbeans.modules.javascript.editing, org.netbeans.modules.javascript.hints, org.netbeans.modules.javawebstart, org.netbeans.modules.jumpto, org.netbeans.modules.kenai.ui, org.netbeans.modules.localhistory, org.netbeans.modules.maven, org.netbeans.modules.maven.grammar, org.netbeans.modules.maven.graph, org.netbeans.modules.maven.hints, org.netbeans.modules.maven.j2ee, org.netbeans.modules.maven.jaxws, org.netbeans.modules.maven.repository, org.netbeans.modules.maven.search, org.netbeans.modules.mercurial, org.netbeans.modules.mobility.deployment.ftpscp, org.netbeans.modules.mobility.deployment.ricoh, org.netbeans.modules.mobility.deployment.webdav, org.netbeans.modules.mobility.end2end, org.netbeans.modules.mobility.jsr172, org.netbeans.modules.mobility.project, org.netbeans.modules.mobility.svgcore, org.netbeans.modules.options.editor, org.netbeans.modules.properties, org.netbeans.modules.refactoring.api, org.netbeans.modules.registration, org.netbeans.modules.server, org.netbeans.modules.spring.beans, org.netbeans.modules.subversion, org.netbeans.modules.swingapp, org.netbeans.modules.terminal, org.netbeans.modules.tomcat5, org.netbeans.modules.versioning, org.netbeans.modules.versioning.system.cvss, org.netbeans.modules.versioning.util, org.netbeans.modules.vmd.componentssupport, org.netbeans.modules.vmd.game, org.netbeans.modules.vmd.inspector, org.netbeans.modules.vmd.midp, org.netbeans.modules.vmd.midp.converter, org.netbeans.modules.vmd.midpnb, org.netbeans.modules.vmd.model, org.netbeans.modules.vmd.palette, org.netbeans.modules.web.beans, org.netbeans.modules.web.client.tools.api, org.netbeans.modules.web.freeform, org.netbeans.modules.web.project, org.netbeans.modules.websvc.core, org.netbeans.modules.websvc.customization, org.netbeans.modules.websvc.design, org.netbeans.modules.websvc.manager, org.netbeans.modules.websvc.metro.model, org.netbeans.modules.websvc.metro.samples, org.netbeans.modules.websvc.restapi, org.netbeans.modules.websvc.saas.codegen, org.netbeans.modules.websvc.saas.services.strikeir on, org.netbeans.modules.websvc.saas.ui, org.netbeans.modules.websvc.utilities, org.netbeans.modules.websvc.wsitconf, org.netbeans.modules.xml, org.netbeans.modules.xml.jaxb, org.netbeans.modules.xml.tools.java, org.netbeans.spi.editor.hints, org.sunspotworld.SPOTFRCwelcomemodule, org.sunspotworld.sunspotfrcapplicationtemplate] use org.jdesktop.layout which is deprecated: Use javax.swing.GroupLayout instead. (In form editor: select Form ... in Inspector; change Layout Generation Style to Standard Java 6 code.)
WARNING [org.netbeans.core.projects.cache]: layer jar:file:/C:/Users/Connor%20Moroney/.netbeans/6.9/modules/edu-wpi-first-wpilibj-templates.jar!/edu/wpi/first/wpilibj/templates/layer.xml contains duplicate folders named Templates/Project/Samples/FRC Java
Could not open SDK Home: C:\Users\Connor Moroney\SunSPOTFRC
java.lang.OutOfMemoryError: Java heap space
at org.netbeans.JarClassLoader$JarSource.resource(Jar ClassLoader.java:543)
at org.netbeans.Archive.getData(Archive.java:199)
at org.netbeans.JarClassLoader$JarSource.doGetResourc e(JarClassLoader.java:504)
at org.netbeans.JarClassLoader$Source.getResource(Jar ClassLoader.java:337)
at org.netbeans.JarClassLoader.findResource(JarClassL oader.java:272)
at org.netbeans.ProxyClassLoader.getResource(ProxyCla ssLoader.java:375)
at org.netbeans.core.startup.NbResourceStreamHandler$ Connection.connect(NbResourceStreamHandler.java:11 4)
at org.netbeans.core.startup.NbResourceStreamHandler$ Connection.getInputStream(NbResourceStreamHandler. java:202)
at java.net.URL.openStream(URL.java:1010)
at edu.wpi.first.squawksdk.Installer.isSdkCurrent(Ins taller.java:130)
at edu.wpi.first.squawksdk.Installer.startRoutine(Ins taller.java:53)
at edu.wpi.first.squawksdk.Installer.restored(Install er.java:42)
at org.netbeans.core.startup.NbInstaller.loadCode(NbI nstaller.java:426)
at org.netbeans.core.startup.NbInstaller.load(NbInsta ller.java:366)
at org.netbeans.ModuleManager.enable(ModuleManager.ja va:944)
at org.netbeans.core.startup.ModuleList.installNew(Mo duleList.java:318)
at org.netbeans.core.startup.ModuleList.trigger(Modul eList.java:254)
at org.netbeans.core.startup.ModuleSystem.restore(Mod uleSystem.java:286)
at org.netbeans.core.startup.Main.getModuleSystem(Mai n.java:172)
at org.netbeans.core.startup.Main.start(Main.java:302 )
at org.netbeans.core.startup.TopThreadGroup.run(TopTh readGroup.java:114)
at java.lang.Thread.run(Thread.java:662)
EX Team member and mentor of TEAM 1100!!! The T-hawks!!!
Finalists WPI regional 2011 along with 177 2011
Winners of the engineering excellence award at Boston Regional 2011
WPI regional 2013 Chairmans award winners
Now the runaway renegade.
Unread 21-01-2012, 16:55
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Good to hear you got it fixed. I have found two things over the years:
1) Always read and follow the documentation carefully. Even if you've done it for years there is often new twist, step, or caveat.
2) If the docs 'suggest' something, assume it was the only thing thoroughly tested.
Every year I try and do it the 'quick' way, and every year I end up going back to the docs and fixing something that would have worked (and taken less time) if I had gone step by step. One day I will learn.
Unread 21-01-2012, 16:57
AKA: Connor Moroney
umm this is akward because i did not get it fixed
Unread 21-01-2012, 17:01
Your log says Out of Memory. Either close open programs that may be using memory, upgrade your computer's memory or try a different machine with more available memory.
Unread 21-01-2012, 17:04
AKA: Connor Moroney
i will be trying the more memory idea soon hopefully, will post back if that works, but usualy netbeans is the only program open.
Unread 21-01-2012, 17:06
AKA: Jim O'Malley
Is the above path correct? Is the path write-able by the user installing it? (double check, even if you are sure, because something odd is going on here)
I don't have a development laptop in front of me right now, but I am pretty sure that <user home>/sunspotfrcsdk is the usual directory.
Unread 21-01-2012, 17:08
AKA: Jim O'Malley
Yes it is
I was replying to DaveFrederick and your message popped in between!
Timing is everything
Unread 22-01-2012, 21:07
AKA: Connor Moroney
hay everyone, turns out that out of memory means out of memory, i stuck a 1gb stick of ram in the laptop today and things immoderately started working again.
