I am trying to use camera tracking to track the reflective tape, but I am having problems with the frcParticleAnalysis function. I'm not sure how to use it. my code is:
#include "WPILib.h" /** * This is a demo program showing the use of the RobotBase class. * The SimpleRobot class is the base of a robot application that will automatically call your * Autonomous and OperatorControl methods at the right time as controlled by the switches on * the driver station or the field controls. */ class RobotDemo : public SimpleRobot { RobotDrive myRobot; // robot drive system Joystick stick; // only joystick Jaguar jag1; Jaguar jag2; Solenoid Sol1 ; Joystick stick2; HSLImage image; ParticleAnalysisReport par; BinaryImage image2; public: RobotDemo(void): myRobot(1, 3, 2, 10), // front left, rear left, front right, rear right stick(1), //these must be initialized in the same order jag1(7), jag2(8), Sol1(8), stick2(2) { myRobot.SetExpiration(0.1); } /** * Drive left & right motors for 2 seconds then stop */ void Autonomous(void) { myRobot.SetSafetyEnabled(false); AxisCamera &camera = AxisCamera::GetInstance(); camera.WriteBrightness(0); Wait(3.0); myRobot.MecanumDrive_Cartesian(0.0, 0.0, 0.0, 0.0); // stop robot while (!IsOperatorControl()) { camera.GetImage(); frcParticleAnalysis(image2, 5, par); /*the error says "cannot convert 'BinaryImage' to 'Image*' for argument '1' to 'int frcParticleAnalysis (Image*, int, ParticleAnalysisReport*)'*/ } } /* * Runs the motors with single stick holonomic steering. * comment */ void OperatorControl(void) { while (IsOperatorControl()) { myRobot.SetSafetyEnabled(true); myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetThrottle(), 0); // drive with arcade style (use right stick) if(stick.GetTrigger()) jag2.SetSpeed(.8); jag1.SetSpeed(.5); Wait(.2); Sol1.Set(true); if(stick2.GetTrigger()) jag1.SetSpeed(.5); else Sol1.Set(false); jag1.SetSpeed(0); jag2.SetSpeed(0); Wait(0.005); // wait for a motor update time } } }; START_ROBOT_CLASS(RobotDemo); |
Re: Particle Analysis Report Problems
You declare your variable image2 as a BinaryImage*, which is why the compiler is having trouble. It sees parameter 1's type as "BinaryImage*", but it is looking for Image*. Also, you don't assign anything out of your call to camera.GetImage(). It should be something like image2 = camera.GetImage() [except that might not be the right type. Check out AxisCamera.h to find out what GetImage() returns].
I don't have the code in front of me, but it is likely that what you need to do is do something like this: ColorImage colorImage; camera.getImage(&colorImage); frcParticleAnalysis(&colorImage, 5, par); However, we had success last night doing something different. We did something very similar to this. It is unlikely the code below or above will compile, it's coming out of memory. ColorImage img; camera.getImage(&img); BinaryImage* binImg = img.ThresholdRGB(192,256,192,156,192,256); vector<ParticleAnalysisReport>* particles = binImg->GetOrderedReport(); // I don't remember this function's actual name for(int x = 0;x < particles.size(); x++) { ParticleAnalysisReport& par = (*particles)[x]; // do something with par: look at par.center_mass_x, par.center_mass_y, etc. } Last edited by Bongle : 20-01-2012 at 22:52. |
Could you please post you actual code when you come in? It looks really good and I'd really like for my team to have camera tracking this year. Thanks so much!
this is my autonomous code as it stands now. can you guys help me figure out what to do/where to go from here.
void Autonomous(void) { myRobot.SetSafetyEnabled(false); AxisCamera &camera = AxisCamera::GetInstance(); camera.WriteBrightness(0); Wait(3.0); myRobot.MecanumDrive_Cartesian(0.0, 0.0, 0.0, 0.0); // stop robot while (!IsOperatorControl()) { /** ColorImage &colorImagel; camera.GetImage(&colorImage); frcParticleAnalysis(&colorImage, 5, par); **/ HSLImage img; camera.GetImage(&img); BinaryImage* binImg = img.ThresholdRGB(192, 256, 192, 156, 192, 256); vector<ParticleAnalysisReport>* par = binImg->GetOrderedParticleAnalysisReports(); //warning: unused variable 'par' for(int x = 0; x < 5/**par.x**/; x++) { ParticleAnalysisReport& par = (*particles)[x]; //error: 'particles' undeclared (first use this function) int x; par.center_mass_x = x; //do something with particles: par.center_mass_x & par.center_mass_y } } } thanks for the help Last edited by Cody Trey : 21-01-2012 at 14:39. Reason: for got to put a question... |
Wait(3.0);
ColorImage img;
vector<ParticleAnalysisReport>* particles = binImg->GetOrderedParticleAnalysisReports();
for(UINT32 x = 0; x < particles->size(); x++)
if(par.center_mass_x_normalized > 0) { /* turn right */ }
else if(par.center_mass_x_normalized < 0) { /* turn left */ }
If you're focused JUST on autonomous however, don't forget the physical approach: put an aiming device on the robot, and have your drive team place and aim the robot using that. That removes the need to use the camera at all, mostly. You wouldn't get aiming in teleoperation mode, but if the goal is just autonomous, you can achieve it with just an on-robot aimer. It's actually what we did last year. Last edited by Bongle : 21-01-2012 at 15:39. |
awesome, well I have one more error to fix then I can just wait until electrical and mechanical have there stuff finished...
BinaryImage* binImg = img.TresholdRGB(192, 256,156, 192, 256); //error: request for member 'ThresholdRGB' in 'image', which is of non-class type 'ColorImage*' do I need to make img in to an RGB imag rather than just a Color Image? |
#7
The declaration for ColorImage should be: ColorImage img; From the compiler error, it sounds like you have ColorImage* img; That would be a pointer, which is why you can't do img.ThresholdRGB(...) |
#8
ok, when I do that i get
ColorImage img; //error: no matching function for call to 'ColorImgae::ColorImage()' camera.GetImage(&img); if you want I'll post the whole code as it stands now if you think it'll help Last edited by Cody Trey : 21-01-2012 at 17:01. Reason: forgot the '&' |
#9
I believe it is: ColorImage img(IMAQ_RGB_IMAGE); You'll have to take a look at the constructor for ColorImage. Click on it, hit f3, and see what enumeration it requires. Hit f3 of the enumeration type, and it should take you to a list of options. You want the RGB one. Unfortunately, I'm once again at home, so I don't have our code in front of me. |
#10
As I'm always saying to our students - code compiling doesn't mean the code works :-)
#12
If you run into issues tracking with an RGB image, try using HSL instead.
- Bryce |
#13
Now that I've finially had a chance to test the code, I'm getting errors when we try to run it. Quote:
do you think using a different image type would help? |
#14
They're all probably related to the same error. You'd have to post the exact code you're using to call the ThresholdRGB function for me to have a clue.
Edit: the code I posted above that has the ThresholdRGB call has a problem. It should be ThresholdRGB(192,256,192,256,192,256) I put a 156 where 256 should have been. Last edited by Bongle : 03-02-2012 at 19:30. |
#15
I'm going to comment only on this single correction about the 156 versus 256...
Threshold takes 8-bit numbers for its thresholds. 256 is **NOT** an 8-bit number. 8-bit numbers range from (unsigned) 0-255 or (signed) -127 to 128. If you are passing 256 into this routine, you are likely passing a ZERO or an invalid number based upon the way Threshold processes it or passes it to the imaq functions. 255 is a MAX number .... bob |
