Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Unread 21-01-2012, 16:43
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Motor Error
We are getting this error:
Missing Module: Digital Module 1
WPI_PWMChannelCache.vi>>WPI_MotorControlOpen&Confi gurePWM.vi>>WPI_MotorControlOpen Jaguar.vi>>WPI_RobotDriveOpen2MotorWithJaguar.vi>> Begin.vi>>Robot Main.vi
<time>00:11:58 01/01/1970<unique#>3162
We are getting this error in WPI_RobotDriveRefNum Registry Get.vi Front Panel on 2012 Robot.
We're trying to get the robot to drive off of the basic program that FRC provides. The Jaguar speed controllers flash yellow. Also, the ribbon cable has been fixed.
Unread 21-01-2012, 16:58
Re: Motor Error
Is the Digital Module that the ribbon cable is attached to in Slot 2 of your cRIO?
Unread 21-01-2012, 17:02
FRC #4084
Re: Motor Error
It is either in slot 1 or slot 4. We don't know which one is the front. If the ethernet port is on the right where the observer it is in the furthest slot to the left.
Unread 21-01-2012, 17:04
Re: Motor Error
It belongs in Slot 2. Slot 1 is the side with the Ethernet port on it. Move the Digital Module and see if the error clears (the green LED next to the white 2 pin header on the Digital Sidecar should also start blinking).
Unread 21-01-2012, 17:34
FRC #4084
Re: Motor Error
Well we got one of the motors working without fixing the physical slot. We changed something to digital module 2 but only one motor works now.
Unread 21-01-2012, 17:37
FRC #4084
Re: Motor Error
we also have the controlled mapped to both motors so it has to be something in labview
Unread 21-01-2012, 17:43
Re: Motor Error
If you have it in slot 4 you can get things working by using Digital Module 2 in LabVIEW, but per the rules you must have a Digital Module in Slot 2 of the cRIO so you might as well move it now.
Unread 21-01-2012, 17:57
FRC #4084
Re: Motor Error
Just mioved it and the same problem, however we were seeing the PWM outputs both times and nothing was happening so we replaced the non moving jaguar and nothing is working again. Both sides are jaguars by the way.
Tried putting from PWM 1 and 2 to PWM 1 and 3 for both motors. PWM 1 is the working one
