Go to Post "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein - Edward Debler [more]
Unread 21-01-2012, 16:47
team4139 team4139 is offline
FRC #4139
team4139 is an unknown quantity at this point
Anything under the frame
Is there a rule that says you cannot have anything underneath the frame? We are planning to have a ramp that is fixed onto the robot. It'll help the ball into the robot. Is any object allowed beneath the robot bumper? Or should we have a motor that'll drop the ramp down after the start of the match.
Unread 21-01-2012, 16:57
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Anything under the frame
You are allowed to have any compliant components within the frame perimeter's vertical projection such that they do not exceed 60" at the start of the match.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 21-01-2012, 17:22
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
I would still suggest having the ramp retractable. Then it will not snag things, and it can be used as an extra way to keep balls in. I don't know your design though
Unread 21-01-2012, 18:07
GaryVoshol's Avatar
Cogito ergo arbitro
Your wheels are under your frame, aren't they?
Now if you mean something sticking out underneath and beyond the edge of your frame, well then, that's your appendage. It must be inside the Frame Perimeter at the start of the match, and you must bring it back inside if you want to use another appendage.
Of course, anything you use must not damage the carpet or other field items.
(since 2004)
