Lifting robot off the ground
Our team wants to know if we can push the robot up to meet the bridge when getting over it. We want to use the weight of the robot to our advantage when balancing.
I know there is a rule about the vertical projecction but does this fall into that category? |
Re: Lifting robot off the ground
Last I've checked, there are no restrictions on using appendages, either in the 14" horizontal allowance or in the vertical allowances, to touch the ground from the bridge. (There are restrictions on whether leaving said appendages touching the ground results in a balanced bridge.) |
On your side of the field you are aloud to be 84 in tall; if you are touching the oposite aliance carpet you can only be 60 in tall. See rule [R02].
You may be thinking of the 14" horizontal limit for appendages. |
The rule in question here I believe is the bumper zone limits. The bumpers always have to be within the 2-10 inch zone, in reference to the carpet if that's what you're in contact with. If you lift your robot up, you would be out of the bumper zone and illegal, at least according to my interpretation.
#7
Does your interpretation take into consideration the latest revision of [R01-2]?
#8
I hadn't seen that update when I replied. I believe the intent is to allow temporary exemption from the bumper zone requirements while crossing the bridge and bump. Lifting up a robot would seem to be legal if actively crossing the bridge or bump, or lining up to do so. Is that how you see it?
#9
I believe that the bumper rule must be met always in relation to a flat surface (the carpet, keys, and bridge according to the manual), but will be temporarily exempted if a robot is actively crossing the bridge or bump. The wording still seems to leave it open to interpretation though, there's no definite answer yet I don't believe.
#11
We're also considering the use of pneumatics to lift the robot. Not for getting on the bridge, but to brace it on level ground. As long as max height requirements and bumper zones are met it should be cool.
