Go to Post My own opinion is that any truly great student can succeed with any teacher, and any truly great teacher can succeed with any group of students. - DampRobot [more]
Unread 21-01-2012, 19:10
WarriorRobotics WarriorRobotics is offline
FRC #3676
WarriorRobotics is an unknown quantity at this point
How to turn better with four wheel?
My team is currently using the lift kit so that we can get over the barrier in the middle of the field. We have never done four wheels before, but because of the brackets we are trying it. It is very hard to turn, is there anyway to turn better?
We are currently using 4 independently driven wheels that are at http://www.andymark.com/product-p/am-0514.htm but we have tried 2 wheel drive with all 4 of those wheels, along with 2 wheel drive with the other 2 wheels from the 2011 game. We have also used 4 of those plaction wheels with 2 gearboxes only. None of these systems seem to get even decent turning. Any ideas to help the turning?
Thanks,
WarriorRobotics
Unread 21-01-2012, 19:13
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: How to turn better with four wheel?
Add omni wheels at 2 of the corners or add 2 wheels in the center and drop them an 1/8th inch for a 6 wheel drive. Both will reduce frictional forces that oppose turning.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 21-01-2012, 19:14
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Try using the slick wheels that they gave in the KOP for 2010. Or tr using omni wheels in the front or rear of the chassis. These will greatly aid in turning.
Unread 21-01-2012, 19:19
Buy two more wheels.
Unread 21-01-2012, 19:28
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
4 wheel Crab drive.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 21-01-2012, 19:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
If you are using the kit frame chassis you will notice that the hole for the center wheel is dropped by 1/8 of an inch. This is there so that you can put a 2 more wheels in your drivebase taking if from a 4wd to a 6wd setup and the chassis will rock between the front and back wheels and will greatly improve your turning ability. You can use the 2010 slick wheels or omni wheels on either the front or back to make your 4wd setup turn, but those wheels won't have a lot of traction if any.
You can either buy two more wheels, or use the 4 plactions in the back with 2 8in kit wheels in the front.
1058 PVC Pirates 2016 - xxxx
Unread 21-01-2012, 19:32
But seriously for a second, take a good look at your design.
You have 8" wheels. You do not need a lift kit. You can very easily modify the kit chassis so that the wheels in a 6 or 8 wheel drive are exposed in the front and make contact with the barrier to get over. You don't need the lift kit.
Unread 21-01-2012, 20:16
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I second what akash said, with some slight modification you can avoid the lift kit.
If you want to improve your turning then omni wheels or slick wheels are the way to go. With the slick wheels you could find yourself spinning out if you accelerate too quickly but it is very similar to the plaction wheels you already have so the adjustment would be easier. One piece of advice I would have if you decide to go with the omni wheels is for you to put two of them with alternating rollers for each wheel you replace so that you always have an omni wheel roller contacting the ground.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 21-01-2012, 20:18
Mara's Avatar
Mara Mara is offline
Team 696 Safety Czar
FRC #0696 (Circuit Breakers)
Mara has a little shameless behaviour in the past
Add one to two wheels on both sides and drop the center ones a little to allow for a rocking drive train. This should significantly help out with turning.
Unread 21-01-2012, 20:53
Andrew Lawrence
Posts: n/a
Is there a way to turn better without adding an extra wheel on a wide chassis, or without changing to omni wheels? We would be doing this with 4 wheels, not 8, however.
Unread 21-01-2012, 21:06
jblay's Avatar
AKA: Joe Blay
Moving your wheels closer together or making your bot much lighter is the only thing I can think of.
Unread 21-01-2012, 22:10
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Our team did a 4 wheel driven with "conventional" wheels (not omni, mechanum, or swerve) two years ago and... It didn't work. We used the smooth ones from Lunar Lunacy on the front, and the event I drove (post season, I joined late) I ended up having to go backwards and swing the robot to the left (there was too much weight on the right side!) in increments to get it going the direction I wanted. It was not fun.
Now, if you can't buy omni wheels (either the more expensive omni wheels or two pairs to mount interlaced), which are probably the best solution, I can understand. Our team is so poor we're running out of nuts and bolts! In this case, I would highly suggest you switch to a two-wheel driven design, where the front is powered. The rear wheels should be slick, such as the Lunar Lunacy wheels; if you don't have access to those, I'm sure a local team might have some for you to use, or you could try ripping the treads/rubber off of some other wheels (not sure how they're bonded, though, might not work).
Another option is casters. I've heard them being trash talked on CD a bit, but if you trail them, the wiggle from direction change will be nonexistent and only show up when reversing (to remedy, use smaller wheels). This might not be as cheap as the slick wheels.
Of these options, our team is currently on the first alternative, using lunar lunacy wheels. They will be in the rear, with the front having this year's treaded wheels being driven. We were also making sure to put most of our weight over them (this could also help while balancing three robots, we imagined). Based from my terrible experience with our past robot, this will work much better than having them in the front... We were eventually wanting to switch to casters, but we don't have a way to make them.
If you wish to drive four wheels, and end up using the slick wheels on one side, I would highly trying to drive them at full tilt to break traction during a turn -- I never got a chance to try this, but I think it would have worked on that one terrible robot we had (I just never had time to implement it, long story).
Unread 21-01-2012, 23:08
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
We have had luck using a double set of rubber wheels at the front, and single slick wheels (like from Lunacy in 2009) on the back. This gives you good grip up front but lets the back end of the robot swing around easily. Worked well for us in 2007 and 2011 for positioning to hang tubes, but may not be what you're looking for.
http://www.chiefdelphi.com/media/photos/27552
Unread 22-01-2012, 00:01
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
What's keeping you from REMOVING 2 wheels - you know, segway style?
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 22-01-2012, 00:15
FRC #1984
This is crazy enough to work.
