Go to Post "We just fundraised $5000 for registration, and you spent it all on balloons?" - [more]
Unread 21-01-2012, 17:03
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Question Classmate says theres 0.0 volts
Hello. We are having trouble in our driver station window. The voltage reads zero when I know it should have 12.27 or something. Please help us Thank you
Unread 21-01-2012, 17:06
Re: Classmate says theres 0.0 volts
Make sure you have an Analog Module in slot 1 of your cRIO, with an Analog breakout mounted on it. The Analog Breakout must be powered and the jumper must be installed on the outside two pins of the Battery Selection header. See this doc for a picture of how the jumper should be installed:
http://www.usfirst.org/sites/default...20Breakout.pdf
Unread 21-01-2012, 17:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You need to install the jumper on the analog module in your cRio. Look through the control instructions.
Unread 21-01-2012, 17:11
FRC #3179
Thank you!!!
Unread 21-01-2012, 20:14
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Where might I find these instructions?
Unread 21-01-2012, 20:26
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Getting Started With the 2012 Control System (page 12)
Unread 21-01-2012, 20:30
FRC #0023 (PNTA)
Rookie Year: 1620
Ah, thanks!
