Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Unread 20-01-2012, 20:25
imjessica's Avatar
imjessica imjessica is offline
AKA: Jessica
FRC #4159 (CardinalBotics)
Team Role: Electrical
imjessica is a jewel in the roughimjessica is a jewel in the roughimjessica is a jewel in the rough
eelectrical board minimum size
rookie here! is 17 by 19.5 inches enough space for the electrical board?? this includes 4 speed controllers router crio digital sidecar pd board. battery can be vertical. we have a 45 degree roof so at the tallest side our board has 10 inches of height
thanks so much!!
SF CardinalBotics - Head of Electronics
Unread 20-01-2012, 20:37
Re: eelectrical board minimum size
Allow me to make a suggestion:
Make a paper cutout of the base of every component. Move them around on the board to try to fit them all. It's like a puzzle. If you can't find room for everything, then figure out where else on the robot some items can go (like the router or some of the Jags).
Unread 20-01-2012, 21:53
imjessica's Avatar
AKA: Jessica
thanks thats really helpful im trying that now. that doesnt take the height into account though. do you think its realistic?
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Remember that electrons don't pay much attention to physical orientation. So you can mount your components sideways or even upside down if needed. But make sure the lights on your radio (bridge) are visible from 3 ft away and that your robot signal light is clearly visible. Your field crew will thank you.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 20-01-2012, 22:15
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You also don't need to put all of the components on a single board. Sometimes it makes more sense to distribute the speed controllers, or put compressor relay near compressor, etc.
Unread 20-01-2012, 22:29
DonRotolo's Avatar
Back to humble
FRC #0832
Also note that even though you can put those pieces of paper right next to each other, the wires need room to go in and out too, bigger wires need more room. Also make sure someone can replace wires because that may be necessary during competition.
Unread 20-01-2012, 22:39
imjessica's Avatar
AKA: Jessica
wow thanks everything here was really useful. I think ill do 2 shelves with the battery on the bottom and everything else on top
Unread 20-01-2012, 23:26
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Make sure you make the battery and the main breaker easily accessible.
Unread 21-01-2012, 04:09
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Definetly be sure of these. You'll be frequently removing and replacing batteries between matches to have your robot perform at it's peak, and you need to have easy access to the off switch in case something goes wrong.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 21-01-2012, 15:32
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Kevin Selavko is on a distinguished road
Also make sure that you mount the battery securely on a strong surface; last year we had it being secured by particle board, not a good idea unless you want to drag your battery.
Unread 21-01-2012, 19:32
DonRotolo's Avatar
Back to humble
FRC #0832
Remember that you'll be replacing the battery after every match, so make sure you can do that without great effort. After all, you'll be the one doing it
Unread 21-01-2012, 20:19
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Yeah, don't rely on your electronics board to support your battery unless you use some thick plywood (1/2'') or something. Our battery broke through our 1/4'' plastic board at the finals at our district competition. Had to brace it with a water bottle, rope, and some carefully placed zip ties. It's also nice to have identical components oriented in the same manner (like the power input on jags all facing the power distribution board, etc.) The less spaghetti,
the easier it is to find problems.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 23-01-2012, 08:13
Jess,
You can bend the terminals at right angles to allow wiring to rise straight up from the sides of your speed controllers. This might help getting you r electronics to fit. However, controllers do not need to be grouped together. They can just as easily be placed near the motors they are controlling. The wiring distance is the same. In the case of motors with supplied wires, i.e. the CIMs, place the speed controllers close enough to the motors that you can attache the CIM wires directly to the speed controller. This gives you less connections to add resistance of fail.
