Go to Post My only question is, Can your robot place tetras and deliver Krispy Kremes to team mentors in autonomous mode? - Rich Kressly [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 21-01-2012, 21:04
Betty Boop Betty Boop is offline
Betty Boop is an unknown quantity at this point
(FPGA) high throughput inverse tangent 2 input
Hello! I would just like to ask what is the effect of having a 'negative x' on the high throughput inverse tangent (2 input)? It's because when I have 'negative y' (and 'positive x'), the answer is correct. However, whenever I have 'negative x' (regardless of the sign of y), the answer would always be wrong. Thank you for your time!
Unread 21-01-2012, 21:15
Re: (FPGA) high throughput inverse tangent 2 input
Please give a specific (numerical) example of 2 inputs which gave a wrong output. Give the three numbers X, Y, output.
Unread 21-01-2012, 21:25
*The output is not yet multiplied to pi so that it is expressed in pi radians.
input: y = 1, x = 2
output: 0.1482 (correct)
input: y = -1, x = 2
output: -0.1482 (correct)
input: y = 1, x = -2
output: 0.8542 (even the sign is wrong)
input: y = -1, x=-2
output: -0.8518 (sign is again wrong and from my observation, it doesn't take into account the sign of x)
Unread 21-01-2012, 21:43
input: y = 1, x = 2
input: y = -1, x=-2
Those outputs are all correct. See attachment.
Starting from the +X axis and going counterclockwise, atan2 goes from 0 to +pi
Starting from the +X axis and going clockwise, atan2 goes from 0 to -pi.
Unread 21-01-2012, 21:46
ohh! sorry, sir, but can you please explain the last two cases I've tried manual calculation using calculator
Unread 21-01-2012, 21:51
I edited my original response to add some detail. Please re-read it.
Then read this article:
http://en.wikipedia.org/wiki/Atan2
Then ask me a specific question and I'll gladly help.
Unread 21-01-2012, 22:38
Hi! Now I understand THANK YOU VERY MUCH!
Unread 22-01-2012, 08:41
You're welcome.
May I ask: What is your interest in atan2? Are you taking a math class, or are you using it for FRC?
Unread 22-01-2012, 09:46
No, Sir. I'm using it in determining the phase of a signal given its I and Q data.
