Go to Post rebound rumble didn't really have a lot of rebounding or surprise earthquakes. - Rynocorn [more]
Unread 21-01-2012, 22:29
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: RS-550 and AndyMark am-0928 pinion
Possibly AndyMark is between a rock and a hard place with the bore size on that pinion, because the BaneBot RS-550 shaft seems to be ever so slightly smaller than the AndyMark 9015. One of our pinions was pretty hard to press on to the AndyMark 9015 motor, so a smaller pinion bore might not be desirable, either.
It's great to know that there is a retaining compound that might work if we end up needing the faster flywheel speed from RS-550. Thanks for pointing that out.
