Go to Post I would like to extend my deepest, most sincere thanks to the GDC, for bringing alliances to us in 1999. - Ken Patton [more]
Unread 22-01-2012, 00:17
Andrew Lawrence
Posts: n/a
Re: How to turn better with four wheel?
Originally Posted by Bryscus View Post
What's keeping you from REMOVING 2 wheels - you know, segway style?
Gravity. Friction. The usual, though this does give me an idea:
Dean Kamen created the 2 wheeled segway.
Team 256 will now invent the 1 wheel segway! With 3000 gyroscopes and over 6 lines of code!
Unread 22-01-2012, 00:28
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Originally Posted by SuperNerd256 View Post
Is there a way to turn better without adding an extra wheel on a wide chassis, or without changing to omni wheels? We would be doing this with 4 wheels, not 8, however.
That's interesting...we've had a 4 wheel drive robot at 119.9 pounds before on 6 inch andymark plaction wheels with no problems turning...are you using 4 CIMs in you're drivetrain? If not, this extra torque could aid in turning.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 22-01-2012, 00:30
Andrew Lawrence
Posts: n/a
We are using all 4 CIMs. We actually aren't experiencing problems since we haven't tested yet (Testing tomorrow, can't wait! ), however we wanted to know if there was anything we could do to prevent any problems.
Unread 22-01-2012, 00:38
AKA: Carl Springli
Ah, then I'd bet you'd be fine! A 6 wheel drive narrow chassis breaks up the wheel base into 2, 28 x 19 rectangles (roughly), which is a ratio of 1.47:1. With a wide chassis, you have one wheel base that is a rectangle of 38 x 28 (roughly), which is a ratio of 1.36:1. Now short of vector analysis, that's easy math that can show you the turning abilities should be somewhat similar; don't expect any major changes.
Unread 22-01-2012, 00:45
Andrew Lawrence
Posts: n/a
Thanks!
Unread 22-01-2012, 03:15
WarriorRobotics WarriorRobotics is offline
FRC #3676
WarriorRobotics is an unknown quantity at this point
Really now? Anything you had to do to get it to work like that? We're currently using 4 CIMs and our robot can't turn.
Unread 22-01-2012, 03:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
This may be relevant to your interests. (Look at the diagram, then at the final equations; it's pretty straightforward.)
