Go to Post You really don't want to mess with an engineer. - ChrisH [more]
Unread 20-01-2012, 10:41
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
CIM 1:1
Is there a simple way to hook up a CIM motor to a wheel 1:1? We want to run a simple test.. and don't have onsite access to a CNC machine.
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 20-01-2012, 10:57
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: CIM 1:1
For this application you are really looking for a shaft adapter to go from the CIM motor output shaft to the correct diameter for your wheel. As a very basic prototyping tool we installed a CIM Motor to a Banebots Planetary gearbox with the appropriate gears removed to give an output shaft diameter of .5" and gear ratio of 1:1. However, this can be somewhat complicated to do and we had it laying around in our work area so it was an easy prototyping tool. I would suggest you go with something like a Helical Beam Shaft Coupler from Mcmaster-Carr, http://www.mcmaster.com/#standard-sh...plings/=fw06xw
But that is just a suggestion and I'm sure some other people will have better options and/or suggestions.
Unread 20-01-2012, 11:12
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: CIM 1:1
You can make a quick coupler if you have access to a manual lathe and drill press. This makes a good first project for lathe if you're looking to learn.
KK4KQO
http://voltair.us
Unread 20-01-2012, 11:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: CIM 1:1
+1 to the McMaster Shaft Coupler. Next day shipping FTW.
Unread 20-01-2012, 11:30
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Re: CIM 1:1
The 8mm AndyMark hub might do the trick with a locking collar.
hub
Unread 20-01-2012, 11:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: CIM 1:1
hub
"Out of Stock"
Unread 20-01-2012, 12:25
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Re: CIM 1:1
Easiest way to grab a toughbox and modify the gears in it, you can get it close, about 1:2 just by swapping gears around for testing...
Unread 20-01-2012, 12:47
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: CIM 1:1
Obviously, this is not ideal, but in a pinch you could couple http://www.andymark.com/product-p/am-0588.htm
with
http://www.andymark.com/product-p/am-0096.htm
--Madison--
...down at the Ozdust!
Unread 20-01-2012, 13:28
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: CIM 1:1
AM 8mm shaft adapters would be a good bet, They'll allow you to hook up the CIM to standard 1/2" chain/belt drives for powering the wheel, or to hook straight into a hub to power the wheel.
Attending: MN Duluth Regional
Unread 20-01-2012, 14:22
Re: CIM 1:1
Carolyn,
The CIM is notorious for having bearings that cannot stand a side load. Whatever prototyping you do, if you add side load (i.e. use the wheel on the floor or something else that pushes on the side of the output shaft, be prepared for damage. There also will be very little torque available but a very high speed.
Unread 20-01-2012, 14:24
Re: CIM 1:1
Would this work?
Go to your local auto parts place. Buy a piece of tubing that fits snugly over the wheel axle, and a piece that fits snugly over the CIM's output shaft. Buy a male-male adapter to connect the two different sizes of tubing together. Make the tubing as short as possible, and mount the CIM so it is concentric and coaxial with the wheel axle. The wheel must be separately supported.
Unread 20-01-2012, 14:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: CIM 1:1
Would this work?
This may work, my team has done something similar to connect shaft encoders.
Unread 21-01-2012, 14:56
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: CIM 1:1
We drilled a .313 hole in one end of a .500 " dia axle and used a band saw to cut a slice through the middle of the shaft. Then we took a shaft collar and tighten the set screw to pinch the .500 dia axle onto the CIM axle.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 21-01-2012, 15:01
Re: CIM 1:1
How are you supporting the CIM body. What is supporting the wheel.
Unread 22-01-2012, 03:44
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Re: CIM 1:1
We used a .500 hex rod for the axle of our shooter. One one end we turned the end down for a .500 round bearing and cut a groove for a snap ring. On the other end we used a .500 hexed bearing so we could push the rod through the hexed bearing and add a retaining ring on the round end. The CIM is held in place by two rectangular pieces of sheet metal with the CIM mounting holes one one piece and a clearance hole on the other. There are 4 PEM standoffs that hold the plates together. Drilling the hole in the hex shaft is a easy way to attache the CIM
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
