Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 22-01-2012, 08:50
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Originally Posted by jp1247 View Post
I suppose the question i have is, does the code actually create the communications between cRIO and jaguars? I have an error free deployed code, but the light on the jags continue to blink yellow (no signal).
Yes, it creates the communication. You use it just like the other objects after instantiation for open loop control. Start simple. Try using just one Jaguar to start with and set it to a constant value. Reuse the cable you made for programming the Jags to be sure that isn't a problem.
Does your Allen Bradley signal light blink? They moved the modules this year (not sure if other stuff is working). You also need to make sure the switch on the cRIO is set to off for the console. Check NetConsole for error messages.
C++ code
CANJaguar m_motor(5);
m_motor.Set(0.1);
Pretty simple most of the time. Or:
CANJaguar *m_motor;
m_motor = new CANJaguar(5);
m_motor->Set(0.1);
I think you have to use the latter to pass to RobotDrive...
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 22-01-2012, 10:12
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Re: cRIO serial-CAN no signal
I don't actually recall if our signal light blinks, it's half hidden at the top of our bot. I know the modules are correct, I had the robot driving on PWM second day of the season with new firmware and such. I will try with just one jaguar today, and see if I can get any results. I will be with robot today until about 4 pm EST if there any specific questions that you want me to answer.
Thanks.
"No, you can't use the Kinect to do pelvic thrusts."
