Go to Post adulthood is overrated. people just give you wierd looks when you play with your transformers, nerf guns and lightsabres. - Tytus Gerrish [more]
Unread 22-01-2012, 10:15
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: [FTC]: Robots running on at end of Teleop., and strange FCS Joystick behavior.
Originally Posted by alphadog0309 View Post
This tells me that FIRST should create a "Kill at 1:57:050" VI for teams to put into their code as it is obviously a big problem. Or they should out right fix the issue and do this the correct way....
This assumes that there isn't a temporary loss of communications during the match that would cause the timer to reset.....
The timer has to start when the robot is enabled... for the first time..
Phil Malone
http://www.GEARSinc.org
