Re: Sending data to cRIO
If you're sending data between the cRio and a laptop on the robot (connected to the bridge or 2nd cRio ethernet port), it would seem that UDP datagrams are the simplest solution, as they are easy to implement (a UDP listener does not require more than one thread, and a UDP sender is a synchronous call requiring no state at all)
Kettering Motorsports
