Go to Post being surgically altered to have two right hands is a big commitment, but if you wanna drive, and drive well ..... ! - KenWittlief [more]
Unread 22-01-2012, 17:07
Re: Labview Error 7
When you imaged your cRIO, which CAN support plugin did you choose?
Unread 23-01-2012, 19:27
Powerhawks1111 Powerhawks1111 is offline
FRC #1111
Powerhawks1111 is an unknown quantity at this point
Re: Labview Error 7
We do not know. How does one aquire such information?
Unread 23-01-2012, 23:51
Re: Labview Error 7
Ask the person who imaged your cRIO what they chose.
You select the plugin from the available options in the FRC 2012 cRIO Imaging Tool. The list is labeled "CAN Driver Plugin" and is in the middle of the left side of the window.
Select the option that matches the hardware you're using as a CAN gateway, and Apply the changes.
