Go to Post There can be a fine line between intimidation and inspiration when it come to the elite in FIRST. Those teams who have committed to setting the bar for excellence in ways that change the culture, help to draw that line and deepen it. - JaneYoung [more]
Unread 22-01-2012, 17:45
meltbox360 meltbox360 is offline
FRC #4302
meltbox360 is a glorious beacon of lightmeltbox360 is a glorious beacon of lightmeltbox360 is a glorious beacon of lightmeltbox360 is a glorious beacon of lightmeltbox360 is a glorious beacon of light
Re: Jaguar Blinking Yellow
^Hah if only there was a like button. And a thanks one to add to that.
EDIT: To clarify the thanks goes to Don for the information provided
I've seen that table but I've also seen someone say it happens when the code never references the controller. I was just wondering if someone could throw code that ran a motor at 50% in autonomous. Default module positions and PWM 1 connected.
As for checking connections. I have a few times and that is exactly why I am perplexed. I have read in one other thread that someone had this problem with 3 out of 4 of their Jaguars. Nonetheless I will check again on Tuesday when I am in front of the setup. Thank for the help. If anyone has additional ideas or code they could share I would really appreciate it.
